1970 Challenger - Lower DVR Door Hinge, S Spring Broke #1924002
10/02/15 10:39 AM
10/02/15 10:39 AM
Florida, US
72ls5fla Offline OP
72ls5fla  Offline OP
Florida, US
Hello ----
was hoping someone could provide the best way to replace a broken lower
door hinge spring.
I looked at things on the car yesterday and can't see an easy way to do this.
I am afraid that the door needs to be unbolted form the hinges and removed from the car.
Any help GREATLY appreciated!
Bill
Got me a NEW Project
1970 GTX 440+6, 4 spd, 4.10 Dana and N96 FE5 (top/bottom) and black bucket interior.
Original transmission and Dana - Engine is a service replacement block.
Body has all stamped #s + VIN/TRIM tag and door sticker. Been hunting like all hell to find the Build Sheet.
garage find, only had 41,850 miles on ODO.
Re: 1970 Challenger - Lower DVR Door Hinge, S Spring Broke [Re: 72ls5fla] #1924044
10/02/15 11:47 AM
10/02/15 11:47 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Yes you need to remove the hinge from the car. Do not remove the door. Just the lower hinge.
Then rebuild the hinge. If it broke the spring chances are the rest of the hinge is worn out. Put new pins and bushings in it while you replace the spring.
The reinstall and adjust the door if needed.
Re: 1970 Challenger - Lower DVR Door Hinge, S Spring Broke [Re: Morty426] #1924165
10/02/15 02:42 PM
10/02/15 02:42 PM
Florida, US
72ls5fla Offline OP
72ls5fla  Offline OP
Florida, US
thank you for the advice....
i will do the total rebuild as suggested. looks like i have a project for the weekend.
just curious if I need to support the door or will the upper hinge hold it up okay and not pinch the back edge of the fender.
What is the best way to get to the bolts?
I am pretty sure one is in the kick panel inside the car, but the two outside ones is there a trick to get at them.
thanks
Bill
Re: 1970 Challenger - Lower DVR Door Hinge, S Spring Broke [Re: 72ls5fla] #1924452
10/02/15 09:09 PM
10/02/15 09:09 PM
Georgia
magiccuda Offline
magiccuda  Offline
Georgia
remove the splash shield from under the fender to get to them.
Re: 1970 Challenger - Lower DVR Door Hinge, S Spring Broke [Re: 72ls5fla] #1924567
10/02/15 11:35 PM
10/02/15 11:35 PM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
Support the door or it will hang down and damage stuff.
I found out recently the lower hinge is the same passenger and driver side on a 68-9 B body, not sure about the Es. Lots of good original passenger lower hinges out there.
Careful, your character's showing!
Re: 1970 Challenger - Lower DVR Door Hinge, S Spring Broke [Re: 72ls5fla] #1924585
10/02/15 11:59 PM
10/02/15 11:59 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Yes support the door
Re: 1970 Challenger - Lower DVR Door Hinge, S Spring Broke [Re: Morty426] #1924670
10/03/15 01:55 AM
10/03/15 01:55 AM
Florida, US
72ls5fla Offline OP
72ls5fla  Offline OP
Florida, US
thanks everyone!
much appreciated.
i will post back after i switch the spring out.
Bill
Re: 1970 Challenger - Lower DVR Door Hinge, S Spring Broke [Re: 72ls5fla] #1924828
10/03/15 12:11 PM
10/03/15 12:11 PM
mopar346 Offline
mopar346  Offline
What part of Florida are you in?
Re: 1970 Challenger - Lower DVR Door Hinge, S Spring Broke [Re: mopar346] #1925450
10/04/15 10:44 AM
10/04/15 10:44 AM
Florida, US
72ls5fla Offline OP
72ls5fla  Offline OP
Florida, US
Tallahassee ..
Re: 1970 Challenger - Lower DVR Door Hinge, S Spring Broke [Re: 72ls5fla] #1925468
10/04/15 11:16 AM
10/04/15 11:16 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Originally Posted By 72ls5fla
Tallahassee ..
I thought the correct answer was "the wet part" grin
