Thank You TO Dave Dudek and Mr Six Pack #1921563
09/29/15 12:04 AM
09/29/15 12:04 AM
Beeware Offline OP
Beeware  Offline OP
Thanks To Dave Dudek !!!
Dave jumped in rolled up his sleeves and helped me pull an oil pan and replace oil pump on the Dyno all while having a car to deliver. I took up his day and made him late but he stayed helped with my Dyno session brought a few parts to test and Made it Happen!!! Thanks Dave !!!!
Thanks To Mr Six Pack also, for the Dyno help, the camshaft & lifters and the valuable experience you've passed along threw out the years !!! Said it before many times if it wasnt for your help I'd be scratching my head wondering what am I doing wrong!!!
Thank You Gentlemen!!!
Paul M Petcou
Re: Thank You TO Dave Dudek and Mr Six Pack [Re: Beeware] #1921595
09/29/15 12:53 AM
09/29/15 12:53 AM
Per your other post, I've had the same thing happen on more than one neow SB oil pump, the problem is that someone at the factory intsalled a BB oil pump bypass valve with no holes in the sides for the oil to bypass through instead of the SB one with those holes runaway I'm glad you guys caught it before it damage the engine or dnyo thumbs
