Differential carrier bearing surface damage #1921363
09/28/15 06:43 PM
09/28/15 06:43 PM
BC, Canada
Black_Bee Offline OP
BC, Canada
Hey guys
I'm building a 8.75" 3.23 Sure Grip diff for my '69 Super Bee by mixing and matching some parts.
Anyway, long story short, while removing the old stuck carrier bearings, somebody trying to help me got carried away with a cutoff wheel and one of the carrier bearing surfaces (on the diff) got cut like 1/16" deep!
Is this differential scrap now, or is this maybe not a too highly stressed area?
Thanks!
beer
Paul
'69 Super Bee 383 EFI Turbo
Re: Differential carrier bearing surface damage [Re: Black_Bee] #1921369
09/28/15 06:51 PM
09/28/15 06:51 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
It's fine , dress any sharp edges and run it
Re: Differential carrier bearing surface damage [Re: Black_Bee] #1921642
09/29/15 02:34 AM
09/29/15 02:34 AM
BC, Canada
BC, Canada
I will do that, thanks for the advice!
beer
Paul
Re: Differential carrier bearing surface damage [Re: Black_Bee] #1921809
09/29/15 02:47 PM
09/29/15 02:47 PM
dogdays Offline
dogdays  Offline
This may be a good time to note that DoctorDiff has new 8 3/4 nodular cases for sale.
Nodular iron has 50% more stiffness than gray cast, which is what the stockers are made out of. Stiffness is what keeps the pinion firmly pressed against the ring gear when you accelerate.
R.
