440 to 700R4 install
#192127
01/13/09 10:47 AM
01/13/09 10:47 AM
I have a 78 Magnum that I am considering putting a 440 and 700R4 into. Has anyone done something similar? Getting the 440 in shouldn't be a problem. There are adapter plates to match the the engine to the GM trans, but I'm wondering about problems connecting my column shifter and the TV cable for the trans, clearance in the trans tunnel, etc.
Thanks for any help!
Re: 440 to 700R4 install
[Re: stumpy]
#192129
01/13/09 11:42 AM
01/13/09 11:42 AM
Posts: 451 Iowa
73ChargerSE440
Iowa
Chrysler 727's are stout trannies, they are behind all hemi/autos
67 Ply. Belvedere II 2dr Hardtop
73 Dodge Charger SE 440+6 727 Dana 60 4.10
78 Chrysler Cordoba 400-4 727 9 1/4 3.21
1999 Dodge Diesel 2500 QuadCab Longbox
2004 Dodge Durango HEMI Limited
#192130
01/13/09 11:50 AM
01/13/09 11:50 AM
Posts: 1,139 West Tennessee
rbstroker
West Tennessee
I understand the overdrive attractiveness of the 700R4 swap, but remember that they didn't hold up very well behind small block Chevies. That's why they upgraded to a new and stronger design.
This is the land of the free
because of the brave
[Re: rbstroker]
#192131
01/13/09 11:58 AM
01/13/09 11:58 AM
Posts: 32,954 Grand Prairie,Texas
stumpy
Grand Prairie,Texas
If you want overdrive in a mopar try the 518(727 with od) swap. That way you can use your existing shifter and kickdown and have a lot stronger trans. I'm doing one behind my 408 stroker. Info at the patc trans site. The switchs they use are for a chevy 350 trans 3 gear clutch are sell for about $5 at the trans supply. The vacuum switch is from a mid 80s caprice and is called a od control. You can pick them and the attached wiring at the junkyard cheap.
#192132
01/13/09 11:59 AM
01/13/09 11:59 AM
Posts: 2,826 NY usa
540challenger
NY usa
The shifter wont work without some mods one to the gates and 2nd the tranny lever will be a bit different [Edited by Moparts - Keep it clean] the different locations
An aftermarket shifter would be alot easier.
The TV cable is no big deal they make a ton of brackets and adjustables tv cables so you should have little 2 no trouble.
Your crossmember may have to be moved but will need to be modifed. Need to pt a flat plate on it for the different gm style mount.
Tranny i think are on the otherside so rerouting the lines will be a must and the ends are totaly different so maybe new lines or just go steel braided stuff.
Also one thing to consider a 700r4 was not a stroung tranny if you are just looking to drive it around with out you will bee fine but the torque from a mild 440 will kill it.
You will need to rebuild the 700r4 to last behind a 440 and in terms off cost to beef up a 700r4 you will get hit in the wallet pretty hard.
[Re: b54406barrel]
#192134
01/13/09 12:39 PM
01/13/09 12:39 PM
Thanks for the advice and suggestions.
I'm thinking 700r4 because I work part time at a Corvette supply shop and can get one cheap out of a car we take apart.
If I do the 440 thing, it will be pretty mild. The Mag is my daily driver, but I want to have some fun with it too. I'm thinking 350-375hp and 450-500 ft/lbs would be good. I don't think that would be too expensive or difficult to do and still have a shot at reasonable mpg if I can put in an OD trans too.
Hot Rod did a 518 install and it looked like a giant pain and, if I remember correctly, they had to manually engage/disengae the OD. Being able to hook up the shifter would be a big bonus though.
[Re: stumpy]
#192136
01/13/09 01:22 PM
01/13/09 01:22 PM
OK, that sounds better. I'll still need an adapter though, right? To go from the big block to a small block trans.
I'm flaunting my ignorance here, but what is PATC?
I'll have to look into using one of the Mopar ODs.
#192137
01/13/09 01:46 PM
01/13/09 01:46 PM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
PATC: http://transmissioncenter.net/their method of controlling a 42/46RH: http://www.transmissioncenter.net/SwapInformation.htmyup, to run behind a bigblock, you'll need either an adapter from JVX, or an ultrabell from JW... another option would be to stay small block and build a 408 stroker or go manual and use an iron case A833OD....
[Re: patrick]
#192138
01/13/09 03:29 PM
01/13/09 03:29 PM
I already have a 440 in the garage. It's been sitting for a while, so I should go through and freshen it up. It should be a pretty painless rebuild though. (famous last words)
I have on old 4spd trns and e-body shifter laying around I might be able to use as trade material for an OD auto. ???
[Re: stumpy]
#192140
01/13/09 03:54 PM
01/13/09 03:54 PM
Thanks for the info. It looks like even tho I'd get a great deal on a 700r4, in the end it will be cheaper and easier to go with the 518.
#192141
01/13/09 04:42 PM
01/13/09 04:42 PM
DaytonaTurbo
Manitoba, Canada
I've priced it out and it's not a cheap conversion any way you go. A 700R4 will need to be built to live behind a 440 and a heavy car like a magnum. They may live behind a 12 second GM car, a car that's no doubt lighter and making less power than a magnum w/ a 440. By the time I priced out buying a core trans, 600 bucks worth of rebuild/upgrade parts to make it live, new longer driveshaft, aftermarket shifter, good quality street/strip torq converter and leaving a few bucks for odds and ends I was already well over 2 grand. I'm sure you could do it for less where you work, but figure out your bottom line before you pull the trigger.
I figured for that kind of money I could convert my car to an overdrive 833 4-speed and row my own gears. Once you deal with the floating shaft issue it's a decently strong trans, then it leaves the door open to upgrade to passon's super strong overdrive gearset later on down the road.
I talked to someone else who installed a 518 into a challenger and his was able to fit with just grinding a little metal off the reinforcement ribs on the 518 case in a couple spots. He said the little he took off had no negitive side-effects, and he did not have to cut his floor open. If it fits a challenger it'll fit a 73+ B body. There was a thread a year or so back showing how to use a couple vacuum or oil pressure sensors to have your overdrive gear and converter engage automatically. That is another viable option, although there was another thread in the race section I think, where a few members were talking about how badly a power sucking transmission the 518 supposedly is.
#192143
07/21/09 10:40 AM
07/21/09 10:40 AM
Posts: 1,949 land of 10,000______'s
BDS871Cuda
There is now way I would run a 700R4 behind any motor. They just don't last with any kind of power or weight.
Running a 440 in a heavy car, just run a 727. If you want freeway speed, just run a 2.90-3.10 gear with a 2200 converter. Guessing this is a street car? The 727 will give you way less head games than any GM overdrive.
Snap your neck, mega G-force launch, is all I want!
[Re: BergmanAutoCraft]
#192144
07/21/09 03:38 PM
07/21/09 03:38 PM
Posts: 2,255 IL
furious70
IL
I have a beefed up a500 in my Fury with OD a lockup, it's great. Tranztech in Dubuque Iowa does them, will do parts only or turnkey. They aren't too far from you in the twin cities. He welds a BB 727 bell to an adapter and it then bolts to the a500 with its bell loped off.
70 Sport Fury 68 Charger 69 Coronet 72 RR
[Re: furious70]
#192145
08/03/09 02:31 PM
08/03/09 02:31 PM
Posts: 451 Iowa
73ChargerSE440
Iowa
Does tranztech do 518 also?
[Re: 73ChargerSE440]
#192146
08/03/09 02:37 PM
08/03/09 02:37 PM
Posts: 2,255 IL
furious70
IL
I'm pretty sure Tim has done a couple for guys who needed more HP capability, yes. The a-500 fits with no tunnel work, that's why it's what he uses mostly.
