Trans Cooler Fittings at the Radiator #192047
01/13/09 01:19 AM
01/13/09 01:19 AM
San Gabriel, CA 91775
rexus31 Offline OP
rexus31  Offline OP
On a stock '65 radiator, are the fittings that the cooler lines connect to threaded into the radiator? Can they be changed?
2007 Dodge Charger R/T, Road and Track Performance Group, Steel Blue 1965 Chrysler 300 Convertible, 383 4V, 727TF, Factory Air, Spanish Red 1964 Pontiac GTO, Tri-Power, 4 Speed, Grenadier Red "What ain't no country I ever heard of. They speak English in What?" - Jules Winnfield
Re: Trans Cooler Fittings at the Radiator [Re: rexus31] #192048
01/13/09 09:40 AM
01/13/09 09:40 AM
Wausau Wisconsin USA North Ame...
radiatorman Offline
radiatorman  Offline
Yes they are threaded and yes they can be changed. Hopefully they were not soldered in sometime in the radiators life. Can still be changed, just a little more work. Take the old fittings to your local parts store and match them up in their brass fitting cabinet.
Good luck!
