pull the alt field wires and pull the reg triangle plug. with some jumper wires: jump fire from the alt batt stud to the nearby field terminal (either one). jump fire to the top terminal nub in the reg. connect the side reg terminal to the other alt field terminal. see how it acts. the HL switch is bad
Well, drove to the garage before I got your most recent reply and this is what it did: Lights Off: At Idle the ammeter flips from slight charge to mid charge, At 1000 RPM flickers at slight charge, At 1600 RPM constant slight charge. Just by turning on the dim lights the ammeter discharged at Idle and slight charged at 2000 RPM. But, with bright lights on it discharged and discharged more with higher RPMs.
After this test, I hooked everything back to normal (I did put a brand new GREEN wire on from the regulator to the FLD terminal on the alternator) and got these results: Lights Off= discharge at Idle and slight charge at 2300 RPM. Lights on= constant discharge.
Didn't see Minivans comment until I got back, but I'll check that next time am at the garage. Thanks.
