407" low deck build
#1920102
09/26/15 03:53 PM
09/26/15 03:53 PM
Posts: 191 WI
mopar873
WI
What experience/results has anyone had doing a .030 bore stock stroke low deck? I'm starting to think I might want to try one. I want a street strip turbo combo for an Abody. I was on a kick of a 451" but now I'm second guessing. I would think that an aftermarket stock stroke crank with BME rods and thick crowned Pistons would be pretty durable. I think with moderate boost on this size engine I would be right at what the block could take with bulletproof guts in the bottom. I've been thinking of this a lot and a recent comment by Jerry Kathe in a different thread goes along the line of the same thinking. Lightweight quality components, lower piston speed, and better bore integrity especially at the bottom of the cylinder? Not a lot of stroke, not turning a ton of rpm, and good geometry? I have a 230 block and a 630 block to work with, that's why I ask.
Re: 407" low deck build
[Re: mopar873]
#1920157
09/26/15 06:13 PM
09/26/15 06:13 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
If you're going with efi, I say go for it. If you're going carb, get a more mistake proof block.
[Re: mopar873]
#1920490
09/27/15 11:00 AM
09/27/15 11:00 AM
Posts: 234 Chapel Hill, NC
orangecrush
Chapel Hill, NC
I built one about 10 years ago that I am running in a 71 Challenger R/T street car and it is still running good. 400 block .030 over, Ross pistons, Manley 6.965 H-Beams, stock 383 crank, 1/2" pickup, edelbrock rpm heads, cut .060 for 71cc, block "0" decked for 10.8 CR, Comp Street XR74R Solid Roller, 750DP Performer RPM Intake, TTI 1 7/8 headers, 3" out the back through Ultraflows. It is a 4 speed car, 3.55. I wish I knew how much power it was making but I never dyno'd it. I know it is fun on the street. Those Manley rods in that size are no longer available. I got the idea to build this combo from Andy F.
[Re: TRENDZ]
#1921556
09/28/15 11:53 PM
09/28/15 11:53 PM
Posts: 285 Northern IL
meathead66
Northern IL
If you're going with efi, I say go for it. If you're going carb, get a more mistake proof block. Sorry but where's the mistake in a 230 block for the OP's application?
[Re: mopar873]
#1922010
09/29/15 08:40 PM
09/29/15 08:40 PM
Posts: 10,016 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Other options are to find a 440 aftermarket crank that needs a regrind. It should be cheap enough needing grinding. Then you can offset grind it down to 3.58 or all the way to 3.50 if you were to go with a 2.1 SBC rod bearing. The nice thing about going with a 440 after market used crank is you can probably get a full history on its' life, and you can build an extremely light rotating assembly by going to the chevy bearing sizes and keeping the piston pin at minimum needed hieght. I would start by finding out what the piston manufacturers want as far as minimum compression height and work from there on rod choices.
[Re: mopar873]
#1922038
09/29/15 09:26 PM
09/29/15 09:26 PM
TRENDZ
Milwaukee WI
Don't put hypers in a blower/ turbo engine.
