4.7 kicked rocker off again #191952
01/12/09 10:23 PM
01/12/09 10:23 PM
Keysville, VA
drag440 Offline OP
mopar addict
drag440  Offline OP
mopar addict
Keysville, VA
I have a 2004 Jeep Grand Cherokee that keeps kicking the cyl.#3 exh. rocker off. It starts ticking first, then the rocker spits out. I think I might have a bad lifter? Is this a common problem? It only has 70,600 mi. on it.
Re: 4.7 kicked rocker off again [Re: drag440] #191953
01/12/09 10:33 PM
01/12/09 10:33 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
You could try swapping that lifter with another one on that bank, and see which one gets tossed next time. Maybe the lifter is going away on you.
Re: 4.7 kicked rocker off again [Re: drag440] #191954
01/12/09 10:34 PM
01/12/09 10:34 PM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
Bad lifter,valve sticking(stem with carbon on it)I would try a lifter first. Any wear on cam lobe?
Re: 4.7 kicked rocker off again [Re: SALEM1912] #191955
01/12/09 11:17 PM
01/12/09 11:17 PM
Mission BC
10sec440 Offline
10sec440  Offline
Mission BC
...or a weak spring!!!
Re: 4.7 kicked rocker off again [Re: SALEM1912] #191956
01/13/09 12:47 AM
01/13/09 12:47 AM
Keysville, VA
drag440 Offline OP
mopar addict
drag440  Offline OP
mopar addict
Keysville, VA
The cam looks good other than a few scrathes on it now. The springs are beehives and they take a lot of pressure to compress them to get the rocker back on. I am going to try to find a lifter tomorow because just before it does it you will hear it ticking.
Re: 4.7 kicked rocker off again [Re: drag440] #191957
01/13/09 11:50 AM
01/13/09 11:50 AM
chicagoland,usa
chicagoland,usa
Hopefully it's just a lifter problem, and not an oiling problem to that lifter. That could get involved. Is that roller spinning real nice on the follower?
Re: 4.7 kicked rocker off again [Re: drag440] #191958
01/13/09 05:49 PM
01/13/09 05:49 PM
Mass
dgc333 Offline
dgc333  Offline
Mass
I had a similar problem with a 2.2 4cyl. The valve guide had come loose and was sliding up and down in the head and every once in awhile it was cause the valve to stick open for just long enough for the cam to get down onto the base circle and out would come the rocker.
Dave Clement Pembroke, MA 03 PT Cruiser GT Turbo 99 Dakota SLT+ CC 4x4 68 Barracuda sport coupe http://home.comcast.net/~dgc333/
Re: 4.7 kicked rocker off again [Re: buildanother] #191959
01/13/09 07:31 PM
01/13/09 07:31 PM
Keysville, VA
drag440 Offline OP
mopar addict
drag440  Offline OP
mopar addict
Keysville, VA
I ordered a lifter today and it will be here tomorrow. The roller spins real free on the follower with no slack.
Re: 4.7 kicked rocker off again [Re: drag440] #191960
01/16/09 10:08 PM
01/16/09 10:08 PM
Keysville, VA
drag440 Offline OP
mopar addict
drag440  Offline OP
mopar addict
Keysville, VA
I put the new lifter in Wed. night along with a can of Valve Medic. The first three times I cranked it, it ticked for about five sec. I have cranked it about twenty times since and drove it to work last two days and so far so good. Keep your fingers crossed for me.
Re: 4.7 kicked rocker off again [Re: drag440] #191961
01/17/09 12:12 AM
01/17/09 12:12 AM
Carlisle, AR.
mdwyer Offline
mdwyer  Offline
Carlisle, AR.
1970 Challenger T/A
1970 Roadrunner RM21 Vcode
1971 Gtx
1971 Satellite
1971 Charger 500 GB5 383 A54 car
1972 Satellite
1997 Dodge 1500 hunting rig
2014 Ram 2500 Mega Cab
