Vacuum Advance - Ported or Manifoeld Vacuum?
#1918483
09/23/15 11:32 PM
09/23/15 11:32 PM
Posts: 4,293 Morrow, OH
markz528
Morrow, OH
Having a brain cramp! Holley 750 DP - is the distributor vacuum advance off the carb base manifold vacuum or is it off the ported port?
Re: Vacuum Advance - Ported or Manifoeld Vacuum?
[Re: markz528]
#1918499
09/23/15 11:57 PM
09/23/15 11:57 PM
RapidRobert
base is manifold. side nipple on metering block is ported (what works best for our Mopars)
[Re: markz528]
#1918509
09/24/15 12:19 AM
09/24/15 12:19 AM
Posts: 3,291 West Coast, USA
jbc426
West Coast, USA
There's two schools of thought on this. If you want better off-idle-and-up drivability, performance and mileage use manifold vacuum. If you want no vacuum advance most of the time except at high speed on the freeway or at medium-to-high rpm with less NO2 emissions use ported.
Either way, you need to have your distributor set up right.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: markz528]
#1918861
09/24/15 04:10 PM
09/24/15 04:10 PM
Posts: 5,170 CT
GTX MATT
CT
I used to think it made more sense to use manifold vacuum because it will give you a better idle. However, I've changed my thinking. I like to use ported now. Get the base timing you want in your timing curve. Otherwise when you stomp on the throttle from idle you're retarding your timing and losing response.
However, if you don't know how or don't want to recurve the dizzy, manifold vacuum will help give you a better idle easily.
You can really set it up however you want though if your customizing it. Older cars used manifold vacuum, most of our cars used ported (anything mid 60s or later). As Andy said above its the same, the ported vacuum is just not active at idle.
On a car with a big cam if the vacuum fluctuates a little at idle running manifold vacuum could cause fluctuating idle timing and make the idle RPM jump around alot. Of course, the idle vacuum fluctuation is exacerbated when it starts pulling and adding timing too.
[Re: STROKIE]
#1919176
09/24/15 11:25 PM
09/24/15 11:25 PM
RapidRobert
an option would be to get the FBO plate ($25 to your door) or make your own & dial it in in both ways & see which one works the best for you. (4) subsystems: initial/total/spring rate/vac can
[Re: STROKIE]
#1919202
09/24/15 11:50 PM
09/24/15 11:50 PM
Posts: 5,444 Indiana
YO7_A66
Indiana
If you have a distributor setup for ported, then use ported. If you have a distributor setup for manifold, then use manifold vacuum. Dont try and run them opposite and you will be fine.
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
[Re: YO7_A66]
#1919312
09/25/15 09:33 AM
09/25/15 09:33 AM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
If you have a distributor setup for ported, then use ported. If you have a distributor setup for manifold, then use manifold vacuum. Dont try and run them opposite and you will be fine. ^^x2. My choice has always been and will always be ported. When ported can't work any more then plug it (rare occasions, and never a street car). That being said it's simply not worth arguing about.
[Re: moper]
#1919424
09/25/15 01:26 PM
09/25/15 01:26 PM
RapidRobert
I cant say I have ever ran manifold mainly cuz I am used to em being plumbed that way OE (ported) & I've only had one carb I've dealt with that had no ported nipple so I just used manifold automatically (had no choice there) & didn't really dial it in for spot on) but sometime when I get caught up & I'm gonna try it (& dial it in for manifold) just to see/be informed & I may like/prefer it
