Re: I must be jinxed!!
[Re: BassMan]
#1918026
09/23/15 01:15 PM
09/23/15 01:15 PM
Posts: 13,363 Marion, South Carolina [><]
an8sec70cuda
How old was the gas in them prior to you just filling them up?
[Re: BassMan]
#1918047
09/23/15 01:35 PM
09/23/15 01:35 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
They do sit for most of the year but they both have fresh gas in them, at least relatively fresh. The 70 Hemi Challenger just filled up about 3 weeks ago and the T/A about 2 days ago. These are common problems w/vehicles that sit and even after 30-40 days I`ve seen varnish and plugged up carbs beyond anything but a rebuild..............just sent out two that were a mess.
[Re: Thumperdart]
#1918117
09/23/15 03:26 PM
09/23/15 03:26 PM
an8sec70cuda
They do sit for most of the year but they both have fresh gas in them, at least relatively fresh. The 70 Hemi Challenger just filled up about 3 weeks ago and the T/A about 2 days ago. These are common problems w/vehicles that sit and even after 30-40 days I`ve seen varnish and plugged up carbs beyond anything but a rebuild..............just sent out two that were a mess. Pump gas is crap and goes bad real fast. If they're gonna sit, get some sta-bil or mix in some race gas.
[Re: an8sec70cuda]
#1918133
09/23/15 03:47 PM
09/23/15 03:47 PM
Challenger 1
Cincinnati, Ohio
They do sit for most of the year but they both have fresh gas in them, at least relatively fresh. The 70 Hemi Challenger just filled up about 3 weeks ago and the T/A about 2 days ago. These are common problems w/vehicles that sit and even after 30-40 days I`ve seen varnish and plugged up carbs beyond anything but a rebuild..............just sent out two that were a mess. Pump gas is crap and goes bad real fast. If they're gonna sit, get some sta-bil or mix in some race gas. Don't use pump gas in a classic car that sits. Use race gas or straight gas with no ethanol like they sell at marinas.
[Re: Challenger 1]
#1918171
09/23/15 04:36 PM
09/23/15 04:36 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Gas going bad with varnish and spiders building nest mess up carbs all the time... even with a air filter on it they some how manage to get in the carb
[Re: BassMan]
#1918236
09/23/15 06:06 PM
09/23/15 06:06 PM
MR_P_BODY
I put StaBil in the gas when they sit for over the winter. I don't think old gas would start fine, run fine and then stall on deceleration. Gas will go flat... it looses the RVP out of it(the high ends of the fuel) even with Stabil... under load the the fuel wont burn properly... the RVP(Reed Vapor Pressure) wont make the high ends which makes the vapor which you actually burn... remember you dont burn the liquid... the vapor makes the BOOM EDIT Under load you need a good fuel and a good ignition
[Re: MR_P_BODY]
#1918304
09/23/15 07:43 PM
09/23/15 07:43 PM
Posts: 540 Northwest PA
BassMan
Northwest PA
I put StaBil in the gas when they sit for over the winter. I don't think old gas would start fine, run fine and then stall on deceleration. Gas will go flat... it looses the RVP out of it(the high ends of the fuel) even with Stabil... under load the the fuel wont burn properly... the RVP(Reed Vapor Pressure) wont make the high ends which makes the vapor which you actually burn... remember you dont burn the liquid... the vapor makes the BOOM EDIT Under load you need a good fuel and a good ignition I really do appreciate the input but the car isn't stalling under load, it's stalling when I slow down. The only time I have ever had a problem with an engine that I really feel was due to old gas was with my outboard motor. My boat had some 3-4 year old gas in the right side fuel tank and it would start and idle fine but did not have enough power to get up on plane. When I switched to the left tank which had fresh gas the problem went away. Before I switched tanks, I checked the plugs and they all looked good except 1 was slightly fouled. Afterwards, I was talking to a marine mechanic and he told me exactly which plug was fouled and he said that was a sure sign of old gas in that motor, it is a 200 hp Mercury EFI.
[Re: BassMan]
#1918307
09/23/15 07:52 PM
09/23/15 07:52 PM
MR_P_BODY
I put StaBil in the gas when they sit for over the winter. I don't think old gas would start fine, run fine and then stall on deceleration. Gas will go flat... it looses the RVP out of it(the high ends of the fuel) even with Stabil... under load the the fuel wont burn properly... the RVP(Reed Vapor Pressure) wont make the high ends which makes the vapor which you actually burn... remember you dont burn the liquid... the vapor makes the BOOM EDIT Under load you need a good fuel and a good ignition I really do appreciate the input but the car isn't stalling under load, it's stalling when I slow down. The only time I have ever had a problem with an engine that I really feel was due to old gas was with my outboard motor. My boat had some 3-4 year old gas in the right side fuel tank and it would start and idle fine but did not have enough power to get up on plane. When I switched to the left tank which had fresh gas the problem went away. Before I switched tanks, I checked the plugs and they all looked good except 1 was slightly fouled. Afterwards, I was talking to a marine mechanic and he told me exactly which plug was fouled and he said that was a sure sign of old gas in that motor, it is a 200 hp Mercury EFI. So have you checked the ignition... or a plugged air bleed
