z bar #1917787
09/23/15 12:03 AM
09/23/15 12:03 AM
arizona, usa
lokalik Offline OP
lokalik  Offline OP
arizona, usa
cant figure out why my z bar is not level. sits low at bell housing. any ideas? frame side ball stud is sitting at the bottom of the notch. thanks
Re: z bar [Re: lokalik] #1917824
09/23/15 12:47 AM
09/23/15 12:47 AM
I ain't a stick guy so this is strickly a BTT for ya but I coulda swore in my stash way back I saw a little flat bracket with a hole and a ball stud which if bolted on the bell threaded boss would raise that end (bell) of the Z bar up. if that is it you might locate or fab one
