Which Drag Radial will work better for my 2010 Challenger #1895821
08/20/15 10:55 AM
08/20/15 10:55 AM
Ringtown, Pa.
Dartsport540 Offline OP
Ringtown, Pa.
I know what kind of slick to use on my race car, But not sure what to use on my 2010 Challenger SRT Hurst Edition, with a Kenne Bell Blower, Automatic. Car has 508 horse power at the wheels. 20" rims x 10" wide. Either Nitto NT555R, or Mickey Thompson 3737R.
I was looking at 2 different drag radials.
http://www.jegs.com/i/Nitto/726/40450/10002/-1?parentProductId=752295#moreDetails
http://www.jegs.com/i/Mickey-Thompson/672/3727R/10002/-1?parentProductId=753925#moreDetails
548 cu. in., Bill Mitchell Aluminum Block, CRT 727 auto trans, Alston Chassis. 8.981et at 149.46 mph. 1.204et - 60 foot, So Far....
Re: Which Drag Radial will work better for my 2010 Challenger [Re: Dartsport540] #1895827
08/20/15 11:13 AM
08/20/15 11:13 AM
New Smyrna Beach FL
scottb Offline
scottb  Offline
New Smyrna Beach FL
I run the nitto tires on my 2012 srt8 superbee and they work great
Re: Which Drag Radial will work better for my 2010 Challenger [Re: Dartsport540] #1895972
08/20/15 03:27 PM
08/20/15 03:27 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I'm going with the M/T but I hear that the 20" wheel kills any solid bite.
Mine makes about the same as yours and 275 BFG'S are not good.
Re: Which Drag Radial will work better for my 2010 Challenger [Re: FastmOp] #1896160
08/20/15 08:39 PM
08/20/15 08:39 PM
Ringtown, Pa.
Ringtown, Pa.
Kenne Bell pic!
Re: Which Drag Radial will work better for my 2010 Challenger [Re: Dartsport540] #1897893
08/23/15 09:01 PM
08/23/15 09:01 PM
Ringtown, Pa.
Ringtown, Pa.
Thanks for the help... I think I am going to go with the Mickey Thompsons...
Re: Which Drag Radial will work better for my 2010 Challenger [Re: Dartsport540] #1916575
09/21/15 10:10 AM
09/21/15 10:10 AM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
The MT's get a better grip but dont last long. Usually 5000 miles for me driving on the street.
It's got a cop motor, a 440 cubic inch plant, it's got cop tires, cop suspensions, cop shocks. It's a model made before catalytic converters so it'll run good on regular gas.
Re: Which Drag Radial will work better for my 2010 Challenger [Re: Dartsport540] #1916580
09/21/15 10:21 AM
09/21/15 10:21 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
The mickeys work better.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Which Drag Radial will work better for my 2010 Challenger [Re: Dartsport540] #1916595
09/21/15 10:54 AM
09/21/15 10:54 AM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Any luck?
I need new tires
Re: Which Drag Radial will work better for my 2010 Challenger [Re: FastmOp] #1916635
09/21/15 11:56 AM
09/21/15 11:56 AM
MR_P_BODY Offline
MR_P_BODY  Offline
My buddy put a new set of Nittos on his vet(stick car)
right before drag week...first and second gear would
just spin.. as soon as he hit third it would pull like
a freight train.. he was turning 11.70s at 126 mph
wave
Re: Which Drag Radial will work better for my 2010 Challenger [Re: Dartsport540] #1916714
09/21/15 02:12 PM
09/21/15 02:12 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
What kind of boost are you putting into your Hurst Challenger? Is that a 2.8L blower? Those things can crank out some serious boost
Re: Which Drag Radial will work better for my 2010 Challenger [Re: Dartsport540] #1917694
09/22/15 09:55 PM
09/22/15 09:55 PM
Ringtown, Pa.
Ringtown, Pa.
I put the Mickey Thompsons on it. I ran it 4 passes at the track, about 8 passes on the street. They hook up great, even on the street.
I could use lower gears, converter change, valve body . But this is my street toy, the Dartsport is for racing. For now I am going to leave it the way it is.
The Kenne Belle blower should be pushing 6 or 7 psi. I may try a smaller pulley next spring.
It ran 12.432, 12.433, 12.523, and 12.492. All passes were 114 mph. Car weighs 4340 pounds with me. 60 foot times, 1.89 and 1.90 .
Re: Which Drag Radial will work better for my 2010 Challenger [Re: Dartsport540] #1917715
09/22/15 10:16 PM
09/22/15 10:16 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
I like the Cuda' look thumbs Cool looking SRT!
You have about 1 sec on my Jeep. I only ran it once and it did a best of 8.66 @ 79 mph in the 1/8.
Re: Which Drag Radial will work better for my 2010 Challenger [Re: Dartsport540] #1918389
09/23/15 09:53 PM
09/23/15 09:53 PM
Home
SRT6776 Offline
I hate internal combustion engines!
SRT6776  Offline
Home
My bone stock Charger 6.4L went 1.91 / 12.91 / 111mph on the stock 245 F1's
IIRC 6.1's with that blower were running in the 11's
You might want to get someone to check the tune, try Mike @ OST Dyno (member here) they can do it over e-mail if you have a Diablo hand held tuner.
