Re: 4 link rear vs leaf springs?
[Re: Spartan040]
#1917428
09/22/15 02:42 PM
09/22/15 02:42 PM
Posts: 27,471 So Cal
autoxcuda
So Cal
I'm considering the pros and cons of leaf springs vs 4 link rear suspension for when I do my Challenger project. What are some advantages of the 4 link vs leaf springs, or vice versa? The new Challenger has a 5 link rear suspension, so I'm assuming that type of system can work better? The new Challenger also has independent rear suspension. And it has a myriad of criteria and constraints that you will not have. There is more than one way to get to the same place. Really need more info from you on what you want. And what other relevant constraints you project might have. Like is there a super wide rear wheel you have to have that's going to require mini or full tubbing? Are you looking to the extra bling or custom visual impact of 4 link tubular rear? ect. What are your end use performance goals? Are you looking for value? . . .
[Re: Spartan040]
#1917616
09/22/15 07:57 PM
09/22/15 07:57 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Leaf springs are great until you reach a torque/traction threshold. Then they either need ditched or a Caltrac type device added. If anyone wants some leafs tested send them my way.
Mopar to the bone!!!
[Re: 72Swinger]
#1917622
09/22/15 08:03 PM
09/22/15 08:03 PM
autoxcuda
So Cal
Leaf springs are great until you reach a torque/traction threshold. Then they either need ditched or a Caltrac type device added. If anyone wants some leafs tested send them my way. You've got mini tubs? wide 315/35/18 grippy rear tires, and had a 451? before?
[Re: Spartan040]
#1917737
09/22/15 10:45 PM
09/22/15 10:45 PM
72Swinger
Nebraska
Leafs have a limit in wrap vs. rate in my experience. If they have no wrap, then they have a bunch of rate. Those Trans Am and Nascars had BEEFY 200+lb springs.
[Re: 72Swinger]
#1918158
09/23/15 04:14 PM
09/23/15 04:14 PM
Posts: 28,068 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Leafs have a limit in wrap vs. rate in my experience. If they have no wrap, then they have a bunch of rate. Those Trans Am and Nascars had BEEFY 200+lb springs. Not necessarily that big of a trade off. The geometry of the leafs help a bunch. That short stiff front segment controls the wrap while the long thin rear segment controls the ride. That's a pretty generic description but true until you get into heavy compression. What it means is that you can control wrap separate from ride.
[Re: Spartan040]
#1918170
09/23/15 04:30 PM
09/23/15 04:30 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Few manufacturers of leaf sprung cars have bothered to optimize it. Most of them have front and rear segment lengths that are the same and then try to control wrap up using extra segments in the front or higher rates, or both.
As for spring rates in NASCAR, not a good example. Downforce plays a huge role compared to anything most of us drive affection rear spring rates there.
[Re: AndyF]
#1919248
09/25/15 01:16 AM
09/25/15 01:16 AM
Posts: 701 Northern California
lilcuda
Northern California
Tim's car was very fast with just stock leaf springs. I think that Eberg added a pair of kicker shocks on the Brick to control wrap up. Spring wrap up doesn't seem like a huge problem to me since I haven't seen very many Mopars that get around a track faster than either the Brick or Tim's Valiant. Still is, although probably not with me behind the wheel! The thing that is interesting about the Valiant is that the front is very stiff, but the rear suspension is very soft by comparison.
'67 is an abbreviation of 1967 67' is an abbreviation of 67 feet They are not interchangeable.
[Re: Spartan040]
#1919519
09/25/15 03:16 PM
09/25/15 03:16 PM
72Swinger
Nebraska
I can very well be guilty of wanting a road course car that withstands a Ronnie Sox impression at will. I don't like laying into the throttle to be mandatory.
[Re: AndyF]
#1919531
09/25/15 03:33 PM
09/25/15 03:33 PM
autoxcuda
So Cal
Some of that is physics, some of it was driver's preference. Last time I scaled that car I think it was still 55/45 front to rear weight. The aluminum heads helped a bunch but the race block is super heavy. With most of the weight on the front tires the springs have to match.
We tried stiffer rear springs (still have some sitting out in the shop) but Tim went back to the old 340 springs since they worked the best. Dang... 55/45 Best for me so far is 57/43. Hopefully aluminum cased 4 spd vs automatic, heater core removal, auto console removal, borgenson steering box and aluminum p/s pump will get me close(r). Just got a set of Intercomp scales for $250. So I've got something handy to play with.
[Re: feets]
#1919548
09/25/15 03:59 PM
09/25/15 03:59 PM
autoxcuda
So Cal
Yep. Thanks. But still a long way to go. No driver, no spare tire, no carpeted trunk mat.
