volare quarter panel #1917396
09/22/15 02:06 PM
09/22/15 02:06 PM
Rochester Pa
79beep Offline OP
79beep  Offline OP
Rochester Pa
my lower quarters on my Volare need replaced behind the rear wheels. my question is I found a mint 4 door at a junk yard and was wandering if they would work from the wheel to the rear bumper on my 2 door?
Re: volare quarter panel [Re: 79beep] #1917659
09/22/15 08:55 PM
09/22/15 08:55 PM
md
mopars4ever Offline
mopars4ever  Offline
md
I don`t think so. Check with 65BelvJim I`m sure he would know.
Re: volare quarter panel [Re: 79beep] #1917860
09/23/15 01:53 AM
09/23/15 01:53 AM
Phoenix - surface of the sun
nomore65BelvJim Offline
How far up the panel do you need to replace?
The 4 door is the same from approx. the middle of the wheel arch back and just above the filler tube opening down.
Re: volare quarter panel [Re: nomore65BelvJim] #1917933
09/23/15 10:36 AM
09/23/15 10:36 AM
Rochester Pa
79beep Offline OP
79beep  Offline OP
Rochester Pa
yes that is the area I need to replace I do not have to go that far up just needed to know if it would work thanks
Re: volare quarter panel [Re: 79beep] #1918589
09/24/15 03:11 AM
09/24/15 03:11 AM
Get the trunk extensions/drops if you need them too. Lots of interchangeability between the 2door/4door/wagon F bodies.
