Using Hoosier Slicks D07/C07 #1917024
09/21/15 09:40 PM
09/21/15 09:40 PM
Salt Lake City
camastomcat Offline OP
Salt Lake City
Tell me about the temperature where slicks like these no longer get tacky. Or better yet, I race on mostly hot tracks. 100+ track temp. But at the beginning and end of the year, the track temp can get down to less than 80 degrees. What compound would you suggest? Or what tires would you suggest? Monte, I hope you're out there. 1850# dragster, approximately 1100-1130HP, 4.10 gear. First I shake and I get a handle on that, then I do burn outs in cold weather. Maybe too much tire pressure? 5 3/4?
Re: Using Hoosier Slicks D07/C07 [Re: camastomcat] #1917063
09/21/15 10:26 PM
09/21/15 10:26 PM
WA
JD Dart Offline
JD Dart  Offline
WA
C07 when the track temp is low do a longer or harder burn out. But being a dragster that may be hard.
