Epoxy Primer then Building Primer? #1916271
09/20/15 07:51 PM
09/20/15 07:51 PM
South
Squirrel_Cat Offline OP
South
I'm knocking down a current reasonable paint job and doing a little bit of metal work on the car as well. 90% of the car is sanded good paint and the rest is bare metal.
I have some Shop-Line Epoxy primer that I used before on a bare metal engine bay and it worked out fine for that application, but it is not sandable at all. It just gums up paper. So I am looking to find out what I should do here,
Can I shoot a coat of Epoxy on the car and when that flashes switch to Building primer so that I can work it? I would prefer to do this as I have a large portion of the interior of the car is bare metal and I would like to shoot that at the same time.
Thanks!
1973 340 'Cuda 2013 Mustang GT
Re: Epoxy Primer then Building Primer? [Re: Squirrel_Cat] #1916297
09/20/15 08:30 PM
09/20/15 08:30 PM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
if you are using shop line filling primer then yes.
if not wait a couple hours, preferably over night, then scuff epoxy primer and sprat filler primer. you SHOULD be ok, but no guarantees.
the reason is because you risk compatibility problems using different brands of primer wet on wet.
sometimes compatibility problems don't show up until you top coat.
perception is 90% of reality
Re: Epoxy Primer then Building Primer? [Re: Squirrel_Cat] #1916352
09/20/15 10:25 PM
09/20/15 10:25 PM
Marilla, New York
RalleyA12 Offline
RalleyA12  Offline
Marilla, New York
Thanks!
If you want a sandable epoxy primer try the Southern Polyurethane brand it sands easily after an overnight dry. They say as long as you apply your primer surfacer within 7 days no sanding is necessary.
Re: Epoxy Primer then Building Primer? [Re: RalleyA12] #1917089
09/21/15 11:04 PM
09/21/15 11:04 PM
Southeast PA
5wndwcpe Offline
5wndwcpe  Offline
Southeast PA
Thanks!
^^This^^
1968 GTX hardtop
1968 Sport Satellite Convertible 383/4spd
1933 Plymouth coupe
2002 Ram 2500 oil burner 4x4
2015 Grand Cherokee
2013 Challenger
1957 Chrysler Saratoga
Man...I need a bigger freakin' garage.
