Welding up holes and making plugs, need advice #1915987
09/20/15 04:22 AM
09/20/15 04:22 AM
Dreaming of the 808
AZ_A12_BEE Offline OP
Dreaming of the 808
I got the bolt in lower firewall of the 37 out and I decided to weld up all the unused holes in them, the smaller holes can just be welded up but the larger ones need plugs welded in. Any suggestions on how to make some round plugs? The metal is 16 guage.
Also should I weld with my Miller 35 and .035 wire or my Miller 110 with .023 wire? I'm using argon/C02 mix for gas.
69.5 A12 Bee, first purchased in 1976, car 169 on registry 69 Coronet R/T 440/4 spd 69 Coronet 500 Conv H code 383 4bbl/auto 37 Plymouth PU Find your spot on earth and ride it.
Re: Welding up holes and making plugs, need advice [Re: AZ_A12_BEE] #1916198
09/20/15 05:36 PM
09/20/15 05:36 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
I've heard guys claim you can plug weld a 3/4" hole or larger with a copper backing spoon.
http://www.harborfreight.com/welding-spoon-66785.html
Re: Welding up holes and making plugs, need advice [Re: AZ_A12_BEE] #1916242
09/20/15 07:01 PM
09/20/15 07:01 PM
WI
W
wannadrag Offline
wannadrag  Offline
W
WI
Find a steel electrical junction box and use the knock outs for the plugs and I use the .023 wire on everything.
Re: Welding up holes and making plugs, need advice [Re: AZ_A12_BEE] #1916259
09/20/15 07:35 PM
09/20/15 07:35 PM
Az
Crizila Offline
Crizila  Offline
Az
.023 wire. Machine screw flat washers on some, but with that many holes to fill, why don't you just cut a new panel and weld it to the hump area? Gonna be a lot of work to make it flat.
Fastest 300
Re: Welding up holes and making plugs, need advice [Re: Crizila] #1916272
09/20/15 07:52 PM
09/20/15 07:52 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
Turn up the wire speed and burn the holes shut. You are lucky the panel is off the car it will be much easier!
Re: Welding up holes and making plugs, need advice [Re: wannadrag] #1916296
09/20/15 08:29 PM
09/20/15 08:29 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Those are galvanized, don't breathe the fumes.
Don't be the exception.
Re: Welding up holes and making plugs, need advice [Re: moparpollack] #1916377
09/20/15 10:50 PM
09/20/15 10:50 PM
Dreaming of the 808
Dreaming of the 808
Shows how rust free the truck is, only broke 1 bolt off and I just drilled an tapped it back out to 1/4-20
Re: Welding up holes and making plugs, need advice [Re: Crizila] #1916380
09/20/15 10:51 PM
09/20/15 10:51 PM
Dreaming of the 808
Dreaming of the 808
Why would I want to make another one? Other than the extra holes there is nothing wrong with it.
Re: Welding up holes and making plugs, need advice [Re: AZ_A12_BEE] #1916383
09/20/15 10:54 PM
09/20/15 10:54 PM
Dreaming of the 808
Dreaming of the 808
Bu my count 27-28 unused unnessasary holes in the lower fire wall, most are 1/8-5//16, those will weld up easy
Re: Welding up holes and making plugs, need advice [Re: AZ_A12_BEE] #1916403
09/20/15 11:11 PM
09/20/15 11:11 PM
85086
Lil Herman
Lil Herman
85086
I stopped counting at 60 holes on my truck.
Re: Welding up holes and making plugs, need advice [Re: moparpollack] #1916469
09/21/15 12:47 AM
09/21/15 12:47 AM
Dreaming of the 808
Dreaming of the 808
There is another 30 on the upper firewall, I will have to just use rubber plugs on those for now.
Re: Welding up holes and making plugs, need advice [Re: AZ_A12_BEE] #1916497
09/21/15 01:38 AM
09/21/15 01:38 AM
Az
Crizila Offline
Crizila  Offline
Az
What's wrong with it is all those holes! To each his own, but since there is nothing special about it ( flat piece of sheet metal, I wouldn't screw around with filling all those holes ( over 60???). You will end up with a better looking floor / firewall with a bunch less work. You already got the template.
Fastest 300
Re: Welding up holes and making plugs, need advice [Re: Crizila] #1921639
09/29/15 02:30 AM
09/29/15 02:30 AM
Dreaming of the 808
Dreaming of the 808
All done with less than 2 hours labor, looks good
Re: Welding up holes and making plugs, need advice [Re: AZ_A12_BEE] #1943132
11/01/15 06:15 PM
11/01/15 06:15 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
So now that the holes are welded in, what was your technique? Copper backing plate , metal filler pieces?
Re: Welding up holes and making plugs, need advice [Re: rowin4] #1955609
11/21/15 11:53 PM
11/21/15 11:53 PM
Dreaming of the 808
Dreaming of the 808
Yes, both those methods, copper backing plate for the small ones, fillers for the big ones
