8 3/4 ? Adjustrer wheel...
#1916218
09/20/15 06:13 PM
09/20/15 06:13 PM
Posts: 2,093 New Mexico
JMCFAN
New Mexico
Pass side axel. Threaded adjuster wheel. How far should this be threaded on to start..? No mention of it in my service manual.... ???
68 Charger 383/ AT Green/Green VT 70 Roadrunner 383/4sp Purple/Black VT
Re: 8 3/4 ? Adjustrer wheel...
[Re: JMCFAN]
#1916223
09/20/15 06:21 PM
09/20/15 06:21 PM
RapidRobert
go on the low side, .005"-.010" EDIT Oh OK I see what you are asking, I was thinking of final end play adjustment
[Re: RapidRobert]
#1916232
09/20/15 06:38 PM
09/20/15 06:38 PM
JMCFAN
New Mexico
so just threaded on a small amount.?
[Re: JMCFAN]
#1916243
09/20/15 07:04 PM
09/20/15 07:04 PM
RapidRobert
make sure as you bolt the axle in with the 5 bolts, that you are monitoring the end play so it is always loose then with the axle bolted in all the way then adj the threaded adjuster to where you have just a hint of in/out movement on the pass side. Regarding this: The flat flange with the 5 holes always seems to fit tight over the stud bolts so best is to tap it down on the studs using easy hammer taps with a drift opposite each other so it is moved in to position flat & not tilted to one side till you get it seated, THEN install/tighten the nuts and then set the end play. OT dont forget to lube the bearing with a needle attachment to your grease gun and that the inner large seal is in place/installed correctly. EDIT just make sure you have end play (any amt) while the axle/flat flange is being tapped into position against the foam gasket/b plate. e brake horizontle lever MUST be out at this point in time
[Re: JMCFAN]
#1916247
09/20/15 07:10 PM
09/20/15 07:10 PM
RapidRobert
so just threaded on a small amount.? yes, just a few turns which gives you the most end play to start with
[Re: JMCFAN]
#1916265
09/20/15 07:44 PM
09/20/15 07:44 PM
Posts: 75,023 U.S.S.A.
JohnRR
U.S.S.A.
The manual is not going to give you a starting point. Start with it most of the way out and do what the manual says to seat the bearing as you adjust it in.
[Re: JMCFAN]
#1916284
09/20/15 08:10 PM
09/20/15 08:10 PM
Posts: 25,823 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The more threads exposed on the adjuster wheel, the more end play the axles will have if everything is properly installed. More end play is good when starting the adjusting process.
