Gauges acting odd #1915768
09/19/15 05:43 PM
09/19/15 05:43 PM
Eugene, Oregon
minivan Offline OP
minivan  Offline OP
Eugene, Oregon
67 Coronet.. Everything new or rebuilt...
Temp gauge was running a little warmer than usual the other night.. Checked water level, fan belt tightness/possible breakage, everything OK..
Happened again and I notice ALL of my gauges ( Voltage, fuel, and temp are all swinging to the right a couple of needle widths more.. As I drive along next look at the gauges, all are acting normal.
As said above, rebuilt gauges by redline, all new wire harnesses, electronic voltage regulator....
Any thoughts on here?? TY
Re: Gauges acting odd [Re: minivan] #1915784
09/19/15 06:16 PM
09/19/15 06:16 PM
electronic voltage limiter on the instrument cluster? I'd check/clean all connections starting with the bulkhead
Re: Gauges acting odd [Re: RapidRobert] #1915792
09/19/15 06:43 PM
09/19/15 06:43 PM
Philadelphia PA
Pynzo Offline
Drugs are bad
Pynzo  Offline
Drugs are bad
Philadelphia PA
X2 with Robert. Too much voltage passing through gauges. Find the fault before they fry. Get another Voltage Limiter.
Re: Gauges acting odd [Re: minivan] #1915794
09/19/15 06:45 PM
09/19/15 06:45 PM
Andrewh Online content
Andrewh  Online Content
or if it is "new" consider replacing the instrument vr.
some of them have been known to fail high and eat gauges.
Re: Gauges acting odd [Re: minivan] #1916147
09/20/15 03:51 PM
09/20/15 03:51 PM
Eugene, Oregon
minivan Offline OP
minivan  Offline OP
Eugene, Oregon
The voltage limiter was supplied by Red Line when they rebuilt the dash.. Probably 10 years ago..
Any recommended suppliers of these?
Re: Gauges acting odd [Re: minivan] #1916166
09/20/15 04:19 PM
09/20/15 04:19 PM
personally I built my on solid state one based on the tech archives.
but a couple of people supply them on the board.
Re: Gauges acting odd UPDATE [Re: minivan] #1943813
11/02/15 05:52 PM
11/02/15 05:52 PM
Eugene, Oregon
minivan Offline OP
minivan  Offline OP
Eugene, Oregon
Update as reported in my other thread, the new voltage limiter seems to have solved it, plus improved the brightness of the dash workings overall.. TY to everyone
