Re: 727 Gasket ???
[Re: okie]
#1915798
09/19/15 07:03 PM
09/19/15 07:03 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Hard trans pan gasket?
Not sure what that is. I can think of three types, cork, rubber and steel cored silicon. Summit has all three typ3es
http://www.summitracing.com/search/department/gaskets-seals/section/transmission-gaskets-seals/part-type/transmission-pan-gaskets/transmission-type/torqueflite-727?N=4294949549%2B4294945238%2B4294923830%2B4294945319&SortBy=Default&SortOrder=Ascending
Re: 727 Gasket ???
[Re: okie]
#1915964
09/20/15 02:23 AM
09/20/15 02:23 AM
RapidRobert
the dealer reinforced pan gasket gets good reviews but in your case I'd try a cheap locally avail gasket & some goop & make sure the pan is flat expecially around the bolt holes (hammer as needed). EDIT I'd get some gasket material some cement some HF hole punches straighten the pan & make one your self, you'll be proud of your work & the distance for a tailor made one will be a non issue
