Coronet Wheel Set Back? #191478
01/12/09 02:01 PM
01/12/09 02:01 PM
Healdsburg, CA
E
El-Rojo Offline OP
El-Rojo  Offline OP
E
Healdsburg, CA
What is the wheel set back for a 66 Coronet? I'm looking at some 8.5" Torque Thrust II's with 3.75" set back.
Thanks,
Mike
Re: Coronet Wheel Set Back? [Re: El-Rojo] #191479
01/12/09 03:19 PM
01/12/09 03:19 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
those wheels probably won't fit with the stock ride heigth. an 8" wheel with a 4 1/2" backspace is probably as large as can be comfortably fit in the wheel well.
Re: Coronet Wheel Set Back? [Re: lewtot184] #191480
01/12/09 10:14 PM
01/12/09 10:14 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
I run 7" steelies with 4-1/4" setback & they are perfectly square in the wheel-well.
Re: Coronet Wheel Set Back? [Re: StealthWedge67] #191481
01/13/09 03:41 PM
01/13/09 03:41 PM
Healdsburg, CA
E
El-Rojo Offline OP
El-Rojo  Offline OP
E
Healdsburg, CA
Thanks for the input. I'll pass on the rims.
Re: Coronet Wheel Set Back? [Re: El-Rojo] #191482
01/13/09 05:24 PM
01/13/09 05:24 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
Thanks,
Mike
I have 18x8 with a 5.5" backspace on my 66 Coronet. The tires are 255/45/18
Re: Coronet Wheel Set Back? [Re: Lefty] #191483
01/18/09 12:16 AM
01/18/09 12:16 AM
Healdsburg, CA
E
El-Rojo Offline OP
El-Rojo  Offline OP
E
Healdsburg, CA
Nice. Mine is a convertable also. Are the spring/ rearend stock? Does it rub loaded?
Re: Coronet Wheel Set Back? [Re: El-Rojo] #191484
01/18/09 01:46 PM
01/18/09 01:46 PM
Lefty Offline
Lefty  Offline
The springs are ESPO 6 leaf HD. The rear is a 742 clutch pack Power Lock.
I have not driven with 4 people yet, but I have a stout rear anti sway bar so I doubt it will rub. I have at least 1/2" clearance at ride height. The rub mark in the photo is from the previous owners tire/wheel combo.
