Resoring my '70 Rally Wheels #1912461
09/14/15 09:19 PM
09/14/15 09:19 PM
FLPlum Offline OP
FLPlum  Offline OP
I have decided to repaint my wheels for my '70 Challenger RT. they are the W21 Rally wheel. In order to correctly (Show), what would the paint for outside and inside look like.
Correct supplier paint codes would even work better, if anyone knows.
Currently they look OK on the outside, but the inside of my wheels are gloss black.
Any assistance to originality is appreciated,
Mike
Re: Resoring my '70 Rally Wheels [Re: FLPlum] #1912511
09/14/15 10:03 PM
09/14/15 10:03 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
The backside of your wheels should be Black. Some will say Gloss others will say Semi-Gloss. The front should be sprayed with Argent without any rear masking so as whatever Argent blows back there is correct. I like Totally Auto's Argent in a spray can for easy of use. Also Mopar Performance sells an Argent Wheel paint also. Don't have a formula if your spraying in a gun.
Ron
Re: Resoring my '70 Rally Wheels [Re: FLPlum] #1912656
09/14/15 11:48 PM
09/14/15 11:48 PM
resq302
resq302
I agree with everything RJS said !
Re: Resoring my '70 Rally Wheels [Re: FLPlum] #1913361
09/15/15 11:06 PM
09/15/15 11:06 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Roger Gibson sells the correct paint for both front and back
Re: Resoring my '70 Rally Wheels [Re: FLPlum] #1914302
09/17/15 10:07 AM
09/17/15 10:07 AM
S.W. Florida
blkbee6pack Offline
blkbee6pack  Offline
S.W. Florida
PPG has a silver poly lacquer that is to be the right color. I can not find the code in my file, but I have seen it on Moparts. I think Bill Alphin has the code. shruggy
Re: Resoring my '70 Rally Wheels [Re: blkbee6pack] #1914307
09/17/15 10:14 AM
09/17/15 10:14 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
It's DLL 3960 I believe. I have sprayed gallons of it on wheels and more. I got the number directly out of a Factory body service manual 20 years ago. And they can still mix it when I checked earlier this year.
