73 up A body SB spool mtr mts: still available new?
#1913319
09/15/15 10:21 PM
09/15/15 10:21 PM
RapidRobert
A guy on FABO has a nice used set for reasonable money ($44 + the ride) & I'm wondering if I should grab em as the ones in the stock car are getting a bit loose (not terrible but are on there way out). thank you for your time.
Re: 73 up A body SB spool mtr mts: still available new?
[Re: RapidRobert]
#1913328
09/15/15 10:25 PM
09/15/15 10:25 PM
Posts: 13,601 md
mopars4ever
md
[Re: mopar346]
#1913334
09/15/15 10:28 PM
09/15/15 10:28 PM
RapidRobert
lightning fast responses! thanks guys. I'll check their prices & go from there.
[Re: mopars4ever]
#1913349
09/15/15 10:43 PM
09/15/15 10:43 PM
RapidRobert
yeah I just swapped in a 318 cuz the 360 is having some issues & I want it running over the winter & on the Dr side the rear ear is closer to the front ear than it is on the 360 so I had to use some washers/spacers. That ebay ad you posted it be ~$53 to my door (not bad). not sure how good they are. I should email him & tell him to put in the ad that they will work on a 318 if the customer is Ok with some simple spacers cuz he did say that they work with 360 only. Might up his sales.
[Re: RapidRobert]
#1913388
09/15/15 11:37 PM
09/15/15 11:37 PM
Posts: 864 St Paul MN
73swinger
St Paul MN
I got a set of 340/360 mounts from engine-swaps.com / Schumacher poly bushings.
Chris Schwartz
73 Swinger 340 12.451 @ 108.78
73 Gold Duster, needs a plan.
[Re: mopars4ever]
#1913956
09/16/15 07:26 PM
09/16/15 07:26 PM
RapidRobert
& this is the stock car so I should probably go with the poly stuff (last longer + be stiffer)
