Clutch recommendation?
#1912803
09/15/15 05:44 AM
09/15/15 05:44 AM
Posts: 84 Norway
cudaerik
Norway
As expected my single disc clutch is giving up behind my 500 cubic low deck stroker and I'm looking into a dual disc set up with some more holding capacity. What would you guys recommend?
I'm looking at the Ram Clutches Force 10.5, McLeod RXT and or the Centerforce DYAD dual disc that is rated at 1300 ft/lbs torque. This car is mostly driven on the street with street tires.
Please let me know what you think.
1970 Plymouth Cuda, 512cid on 230 400 block, 5 speed manual.(TKO 600) 1970 Dodge Charger 500, 446cid, 5speed manual.(TKO 600) 1969 Plymouth Roadrunner, 383cid, 5speed manual (Tremec TKX)
Re: Clutch recommendation?
[Re: cudaerik]
#1912879
09/15/15 11:14 AM
09/15/15 11:14 AM
Posts: 5,161 CT
GTX MATT
CT
What clutch do you have now, out of curiosity?
[Re: GTX MATT]
#1912905
09/15/15 11:41 AM
09/15/15 11:41 AM
Posts: 4,285 Ohio
64dodge572
Ohio
Brewers Performance Inc. 4-speed transmission and parts specialists PH 937-947-4416 or 937-698-4259 FAX 937-947-4419 www.brewersperformance.com
[Re: cudaerik]
#1912909
09/15/15 11:48 AM
09/15/15 11:48 AM
Posts: 21,072 Niles , Ohio
therocks
Niles , Ohio
I run the CF dual friction clutch.My 440 built pushes 600HP.Been in for years and still like new.Hooks super and light pedal.Mine sees lots of street and some strip.Rocky
Chrysler Firepower
