Re: Holley Street Dominator Help
[Re: Beep Beep]
#1912758
09/15/15 01:41 AM
09/15/15 01:41 AM
RapidRobert
get the thin square plate (an eddy # iirc). it'll cover the offending secondary scalloped flange areas. Gasket then the plate then another gasket then the carb. EDIT eddy #2732 adapter, .100" thick
[Re: RapidRobert]
#1912896
09/15/15 11:33 AM
09/15/15 11:33 AM
Posts: 4,743 Moved to N.E. Tennessee
GomangoCuda
Just bolt it on with a good gasket and don't worry about it. Mine worked fine with no leaks for many years. Thin plates are a recipe for a broken carb base.
[Re: Beep Beep]
#1912911
09/15/15 11:50 AM
09/15/15 11:50 AM
Posts: 21,081 Niles , Ohio
therocks
Niles , Ohio
I agree just bolt on.My kid ran mine after I did and we bothe ran DPs with no problems.You might need a throttle bracket but thats it.Rocky
Chrysler Firepower
