Cam Shaft P/N 1970 340*6? #1912174
09/14/15 12:52 PM
09/14/15 12:52 PM
St. Louis
I
Imrare Offline OP
Imrare  Offline OP
I
St. Louis
Looking through the 1970 parts book for the original part number for a 1970 340 6bbl.cam shaft, I only see one listing under 340 and none under 340 6bbl. Are they the same? My parts book has a date of 1972 in the front so I would think it would include a 340*6, but maybe not. Can anyone provide me with the Chrysler part number of the original cam shaft and do you know does anyone make a new factory replacement for this engine?
Re: Cam Shaft P/N 1970 340*6? [Re: Imrare] #1912239
09/14/15 02:31 PM
09/14/15 02:31 PM
CA
crackedback Offline
crackedback  Offline
CA
Same cam as the 340-4.
Re: Cam Shaft P/N 1970 340*6? [Re: crackedback] #1912339
09/14/15 05:44 PM
09/14/15 05:44 PM
Daytona Beach, FL
cknight Offline
cknight  Offline
Daytona Beach, FL
The factory part number would be 2899206. There are three different casting numbers that might be on the core: 2899154, 2899205, or 2899206, depending on when it was produced. The Crane 969361 is a computer smoothed replacement for this part number. Regards, Chase
Re: Cam Shaft P/N 1970 340*6? [Re: crackedback] #1912374
09/14/15 07:06 PM
09/14/15 07:06 PM
North Pole,New York
formula_s Offline
formula_s  Offline
North Pole,New York
except '68 stick.
Re: Cam Shaft P/N 1970 340*6? [Re: Imrare] #1912441
09/14/15 09:01 PM
09/14/15 09:01 PM
St. Louis
I
Imrare Offline OP
Imrare  Offline OP
I
St. Louis
Mopar Performance offers a muscle car cam for the 340 P4452782 with the same specifications the service manual calls out for a 340. Just to confirm, this should be the same cam as used in the AAR/TA motors?
Re: Cam Shaft P/N 1970 340*6? [Re: formula_s] #1912562
09/14/15 10:44 PM
09/14/15 10:44 PM
CA
crackedback Offline
crackedback  Offline
CA
except '68 stick.
Where did he ask about anything other than 1970 and the 70 parts book?
Re: Cam Shaft P/N 1970 340*6? [Re: crackedback] #1919025
09/24/15 07:57 PM
09/24/15 07:57 PM
St. Louis
I
Imrare Offline OP
Imrare  Offline OP
I
St. Louis
Thanks for the information...very helpful.
Re: Cam Shaft P/N 1970 340*6? [Re: Imrare] #1919101
09/24/15 10:05 PM
09/24/15 10:05 PM
dogdays Offline
dogdays  Offline
I'd look into the Crane version for some extra rpm capability.
There's one on Amazon right now for $100 shipped.
R.
