Re: Low Deck Intakes
[Re: HDNMOPERS]
#1912156
09/14/15 12:26 PM
09/14/15 12:26 PM
Posts: 17,926 Akron, Ohio
ProSport
Akron, Ohio
I use Edelbrock RPM heads with cnc max wedge ports done by Muscle Motors.
Welcome to Moparts!
[Re: ProSport]
#1912161
09/14/15 12:34 PM
09/14/15 12:34 PM
Posts: 150 It's Complicated
HDNMOPERS
It's Complicated
The MW port allows you to use the Rb intake on a Low Deck? I seen you can use the RB intake if you use Stage VI heads. Is this the only heads that make this combo possible?
[Re: AndyF]
#1912245
09/14/15 02:44 PM
09/14/15 02:44 PM
HDNMOPERS
It's Complicated
I totally agree. I'm just starting to layout this build. Not sure if will have the hood clearance with a Eddie RPM manifold. Wondering what options I had on the Low Deck head wise for the Indy DP. Looking to do the 512. Wanting to build a torque monster for what I call a Pro Cruise. 62 Dodge 880 2dr hardtop. Thanks for the help guys. Just be ready for some potentially dumb questions.
[Re: HDNMOPERS]
#1912247
09/14/15 02:46 PM
09/14/15 02:46 PM
Posts: 43,332 Bend,OR USA
Cab_Burge
How big C.I. and how much compression and which type tranny and weight of the car? Probally not one size fits all combination on that intake ![work work](/ubbthreads/images/graemlins/custom/work.gif)
[Re: Cab_Burge]
#1912259
09/14/15 03:03 PM
09/14/15 03:03 PM
HDNMOPERS
It's Complicated
I'm thinking alum headed 10.1 10.5 comp Hyd roller type build all in by 5500. Dodge specs list the car I believe at 38 hundred something LBS. I'm thinking more like 4000 big car. Anyway 727 with a 3:00-3:23 gear. That depends on what tire I have under it. Really like to be in the 600 lbs torque mid 5's Hp all in at 5500. If that is possible. Anymore TQ HP than that would be gravy.
[Re: HDNMOPERS]
#1912270
09/14/15 03:26 PM
09/14/15 03:26 PM
Cab_Burge
I totally agree. I'm just starting to layout this build. Not sure if will have the hood clearance with a Eddie RPM manifold. Wondering what options I had on the Low Deck head wise for the Indy DP. Looking to do the 512. Wanting to build a torque monster for what I call a Pro Cruise. 62 Dodge 880 2dr hardtop. Thanks for the help guys. Just be ready for some potentially dumb questions. On your deal I would forget the Indy dual plane and look hard at the M1 dual plane with a Thermoquad carb. That or the Eddy RPM dual plane low deck with a Thermoquad ![scope scope](/ubbthreads/images/graemlins/custom/scope.gif) That is with 440 size intake ports, if you want Max Wedge size intake ports then your choices are very limited, that car woud be perfect with the last generation old long cross ram dual quad set up with a set of eddy RPM heads on your motor, looks killer and runs like stink ![devil devil](/ubbthreads/images/graemlins/custom/devil.gif)
[Re: AndyF]
#1912406
09/14/15 07:52 PM
09/14/15 07:52 PM
HDNMOPERS
It's Complicated
Yeah thinking seriously about doing the Trick Flows. Are the single plane intakes lower than Eddie RPMs intakes. Probably not the ticket for heavy car low stall 3:23 geared street duration hyd roller pump gas engine? I think I just answered my own question. LOL.
[Re: HDNMOPERS]
#1913849
09/16/15 04:58 PM
09/16/15 04:58 PM
Posts: 75,106 A Banana Republic near you.
JohnRR
I totally agree. I'm just starting to layout this build. Not sure if will have the hood clearance with a Eddie RPM manifold. Wondering what options I had on the Low Deck head wise for the Indy DP. Looking to do the 512. Wanting to build a torque monster for what I call a Pro Cruise. 62 Dodge 880 2dr hardtop. Thanks for the help guys. Just be ready for some potentially dumb questions. The Indy dual plane should be pretty close to a Performer RPM in height .
