Re: Small port w8???
[Re: W5DART66]
#1907289
09/06/15 02:58 AM
09/06/15 02:58 AM
Posts: 161 In a house near you
Street Monkies
In a house near you
I want to bring this post back up. The debate about big flow numbers and big ports. I got some info Something I read from a guy in the engine masters challenge. He says "You only have so much time to get the air to move, and you need air velocity to move it. If you don't have 400 feet per second minimum at 28 inches of water [ depression ], you are never going to get the air to move, especially at lower rpm." His heads only have a cross-sectional area of 2.3 square inches. The chamber by the way is 37.5 cc. You might ask why so small on the combustion chambers? Well, the combustion chambers are a by product of the ports and bore size, and the ports actually continue past the valve and into the combustion chamber. The chamber has a reason why the way it is because that's the way the port wants it to be. As far as big flow numbers go.. You can have a big flow number head like in this article that's on totalflowproducts that I am sharing. They proved in the article that better flow numbers doesn't mean more power. Actually a head that flowed less made more power. That was because of certain key things that they changed and tested to back up their results. Check it out and you might learn something. I'm one to share and try and learn something new each day. Also flow benches measure cubic feet per minute not velocity. You can easily kill energy in the port by making it too big.. You don't want to live by some is good, more is better, and big is just right because it's not. http://www.totalflowproducts.com/flow-bench.html
[Re: Street Monkies]
#1908297
09/07/15 10:04 PM
09/07/15 10:04 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
I want to bring this post back up. The debate about big flow numbers and big ports. I got some info Something I read from a guy in the engine masters challenge. He says "You only have so much time to get the air to move, and you need air velocity to move it. If you don't have 400 feet per second minimum at 28 inches of water [ depression ], you are never going to get the air to move, especially at lower rpm." His heads only have a cross-sectional area of 2.3 square inches. The chamber by the way is 37.5 cc. You might ask why so small on the combustion chambers? Well, the combustion chambers are a by product of the ports and bore size, and the ports actually continue past the valve and into the combustion chamber. The chamber has a reason why the way it is because that's the way the port wants it to be. As far as big flow numbers go.. You can have a big flow number head like in this article that's on totalflowproducts that I am sharing. They proved in the article that better flow numbers doesn't mean more power. Actually a head that flowed less made more power. That was because of certain key things that they changed and tested to back up their results. Check it out and you might learn something. I'm one to share and try and learn something new each day. Also flow benches measure cubic feet per minute not velocity. You can easily kill energy in the port by making it too big.. You don't want to live by some is good, more is better, and big is just right because it's not. http://www.totalflowproducts.com/flow-bench.html these cylinder heads got me 5.70s on pump gas at 3000 pounds. With more to come. Thanks again Brett you're the man.
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: W5DART66]
#1908473
09/08/15 03:47 AM
09/08/15 03:47 AM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
Naw just looks strange in that pic. Might need a set next year to try out some new headers!!
Brian Hafliger
[Re: WHITEDART]
#1909788
09/10/15 10:46 AM
09/10/15 10:46 AM
Posts: 792 Earth
Rob C
Earth
hey would like to thank brett miller for all his hard work and time he put in these heads.. I took the heads to QMP RACING hear in so cal ..and had them flow this set of small....... brad at qmp was very happy with these number Ditto with my builder here on the Island who does a lot of "Cup cars" head work. While mine are only the W5 heads, the fellas that flowed the heads we're impressed with the good flow and low swirl stating a really nice and highly efficient port. Damn shame the W5 wasn't up to snuff for more extensive porting! To make an echo.... Thanks Brett
[Re: Rob C]
#1911453
09/13/15 02:05 AM
09/13/15 02:05 AM
Posts: 1,044 Victoria, Australia
Ian
Victoria, Australia
some pics of my junkie w8 s they go 400 cfm with the intake on ,remember we should not hang it on someone for trying something different with the heads ,there is many ways to make hp . [img:center] [/img] [img:center] [/img]
[Re: Ian]
#1912689
09/15/15 12:12 AM
09/15/15 12:12 AM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
some pics of my junkie w8 s they go 400 cfm with the intake on ,remember we should not hang it on someone for trying something different with the heads ,there is many ways to make hp . [img:center] [/img] [img:center] [/img] Looks like a very nice truck port. Who did you get the heads from.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: Ian]
#1912840
09/15/15 09:54 AM
09/15/15 09:54 AM
1967dartgt
Hilltown Pa
i may run it like this with the single and nos my tunes have worked very well so far ,the sheet metal and nitrous will be the crazy deal. the heads are patterson racing and have had a some work done over here by a top pro stock team engine builder.E T A is slow due to sudden setbacks like the r block had a 5 inch crack in the new block its been hard to sauce another r3 but by xmas here with luck. [img:center] [/img] What size valves are you running?
[Re: W5DART66]
#1912867
09/15/15 10:49 AM
09/15/15 10:49 AM
1967dartgt
Hilltown Pa
Wow they flow quite a bit more then my Patterson racing w8's. What valve angle are those?
[Re: J_BODY]
#1912932
09/15/15 12:04 PM
09/15/15 12:04 PM
Ian
Victoria, Australia
Cracked R3..... now that would suck. Hard enough procuring stuff like that over here. I need go to a 4500 on mine, but all in good time. yep parts are like rocking horse ship,they say 30 hp pick up on a change of flange .
[Re: 1967dartgt]
#1912937
09/15/15 12:13 PM
09/15/15 12:13 PM
Ian
Victoria, Australia
Wow they flow quite a bit more then my Patterson racing w8's. What valve angle are those? 52 in ex 45 what cc was your heads
[Re: W5DART66]
#1913603
09/16/15 12:16 PM
09/16/15 12:16 PM
1967dartgt
Hilltown Pa
I was meaning 15°, 13° or what ever they are. They are 320cc. These are from the pro stock truck days when they were involved in racing those
[Re: Ian]
#1914108
09/16/15 11:26 PM
09/16/15 11:26 PM
WHITEDART
bean town ....Ca
Looks like you're going to need some creative spacers in order for that intake to work. However nice looking stuff.. what are your plans, am I missing the flow numbers . 400cfm does not seem to be too difficult to achieve with these cylinder heads..
