Page 3 of 7 1 2 3 4 5 6 7
Re: K frame strength [Re: feets] #1900799
08/28/15 12:39 AM
08/28/15 12:39 AM
SoCal
MuuMuu101 Offline
I got lucky at Woodward!
MuuMuu101  Offline
SoCal
Originally Posted By feets
Goody, I have a couple tons of bar stock and heavy flat stock at home. It wouldn't be hard to put together a rig like your model. That was what I had in mind.
Load testing for the engine weight could be done using an inverted stand. Simple hydraulics could apply the load measured using my proving ring. I have the general Dynamics calibration sheet on the ring that defines loads to 5500 lbs in 50 lb increments. The proper rig would allow testing deflection in heavy cornering due to engine weight as well.
My other gauges and instruments could measure deflection down to .0001" in multiple places.
In my opinion, some tests should demonstrate the strength of the K frame separate from the chassis. Any deflection would show additional load placed on the chassis.
The K should stand on it's own as much as possible and not rely on a relatively flexible chassis for support.
Thoughts?
Ya'll need to do this. And get it in a magazine. With as many K frames as you can get your hands on.
I'm up for it if they are.
I'm down. Unfortunately I don't have a CAD program at home, but I can offer hand drawings and calcs.
Re: K frame strength [Re: Uhcoog1] #1900889
08/28/15 03:47 AM
08/28/15 03:47 AM
Central IL
Trojmn Offline
Trojmn  Offline
Central IL
My current line of belief:
-tire compound matters most
-tire temperature matters second
-tire size matters last
So sure, wider is better, but only if you get the first 2 right.
I also think R compound tires may 'buck the trend' a bit past a certain point. Whereas 200tw tires hold the rule a bit better.
right on! a narrower hot tire is almost always better than a [censored] cold wide tire. I would add: generally maximize the wheel width then the tire, to actually put the tire against the ground.
/thread divert
Re: K frame strength [Re: feets] #1901236
08/28/15 06:17 PM
08/28/15 06:17 PM
Saint Peters, MO
Brian Offline
Brian  Offline
Saint Peters, MO
Kevin,
What stock and modified K's are you looking to test, (A's, B's or E's)?
1971 6.1 Gen III Hemi Duster
Re: K frame strength [Re: feets] #1901361
08/28/15 08:56 PM
08/28/15 08:56 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
I had B bodies in mind since that's the K-frame I have at home.
- Stu Harmon
Re: K frame strength [Re: feets] #1910748
09/11/15 09:21 PM
09/11/15 09:21 PM
NY
X
XVracing Offline
XVracing  Offline
X
NY
Sorry I'm late to the party!!!
I believe you guys are talking about two different things.
Torsional rigidity of the chassis, and deflection of the suspension.
Torsional rigidity is pretty easy to test, you need to lock one end down (rear) you generally need a pivot fulcrum and a big ass lever!!!
You don't need a lot of weight, you can measure how far it deflects for how much weight, calculate that into degrees and pound feet, done.
That is done solid to the chassis and not attached to the suspension.
As Peter said XVM did that 10 years ago and developed an entire chassis stiffening package around that.
Suspension deflection is a whole lot more complicated.
Suspension deflection has to be done dynamically. Twisting a car around the shocks and springs really tells you nothing. The suspension reacts to speed and distance, like pot holes and expansion joints... etc
Tests like that are done on a vehicle driving and or on a test rig like a 4 post.. etc..
XVM also did that 10 years ago and developed the Level II suspension from that data..
CR
Re: K frame strength [Re: XVracing] #1910926
09/12/15 02:18 AM
09/12/15 02:18 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
A K member is a component of the chassis.
Re: K frame strength [Re: feets] #1910967
09/12/15 08:58 AM
09/12/15 08:58 AM
NY
X
XVracing Offline
XVracing  Offline
X
NY
JCC, So what's being tested here, how much rigidity the K frame adds to the chassis?
CR
Re: K frame strength [Re: XVracing] #1911038
09/12/15 11:57 AM
09/12/15 11:57 AM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
CR
That's part of it.
We all know the chassis is floppy. The K frame adds appreciable rigidity by connecting the front rails together. It also has to take the loads from the engine, steering, and suspension.
There are some parts available that do not appear to have the same rigidity as the stock piece. If that's true, guys are spending good money on weaker parts in exchange for a little extra clearance or bit of nifty factor.
Do an eyeball test of these two pieces:
There have also been a few aftermarket members that do not fit and some that have failed structurally.
When buying into these things, what are you really getting?
I imagine you believe in your products. After all, they're your products. The other manufacturers likely feel the same way.
I don't think anyone has done a direct comparison between the products available.
- Stu Harmon
Re: K frame strength [Re: XVracing] #1911064
09/12/15 01:11 PM
09/12/15 01:11 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
CR
I have said this before, most of us will agree on the numerical data, its our own interpretations of the data that will foster many more threads.
Re: K frame strength [Re: feets] #1911137
09/12/15 04:19 PM
09/12/15 04:19 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
The torsional test would validate a K members integrity IMO. That is really the only place it could or couldn't make a difference. But I also can see where people who have had the LCA pivots broken or wallered out would think that THAT is the improvement.
Mopar to the bone!!!
Re: K frame strength [Re: feets] #1911272
09/12/15 09:02 PM
09/12/15 09:02 PM
NY
X
XVracing Offline
XVracing  Offline
X
NY
On track test are really not valid because there are too many variables.
Driver being of the largest variables, chassis setup being another huge one.
I have said this numerous times that the data is only as good as the person reading it. There was another post a while back of a person offering free time on a 4 post shaker rig for testing, nobody took it. Namely because number one, you have to come up with a test that means something, and two you have to be to interpret the data you got from said test.
BTW the K does a lot more than hold the frame rails straight. Again, some things you can't measure statically. It has to support the lower control arms as pointed out, and also support the engine as well as counteract the torque.
Just because the aftermarket K frame doesn't look as big as the factory, doesn't mean it's as strong, or stronger...
A Torsional Rigidity test can be done with the K installed or not, the better the rails are without the K installed, the better it will be with it installed.
My suggestion would be to twist the K members out of the car.
CR
Re: K frame strength [Re: XVracing] #1911280
09/12/15 09:26 PM
09/12/15 09:26 PM
SoCal
MuuMuu101 Offline
MuuMuu101  Offline
SoCal
CR
I agree with most of all what you're saying. There isn't without a doubt that it supports the LCA's and deal with the loads inputted by the engine (weight, torque, vibrational loads). Again, those are all difficult to measure and take into consideration.
A very simple jig could be built to test how much twist the stock K-member has vs. the aftermarket ones. Fix one side of the K-member, apply a lever arm to the other side to input a torque, and measure the deflection using dial indicators.
Re: K frame strength [Re: MuuMuu101] #1911288
09/12/15 09:47 PM
09/12/15 09:47 PM
NY
X
XVracing Offline
XVracing  Offline
X
NY
Exactly what I was thinking... Bolt down 3 of the 4 bolts, jack it on the 4th free one with a scale pad under it...
CR
Re: K frame strength [Re: XVracing] #1911295
09/12/15 10:00 PM
09/12/15 10:00 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
What you are bolting it to, depending on how one is doing the bolting, will add false rigidity.
Re: K frame strength [Re: feets] #1911306
09/12/15 10:09 PM
09/12/15 10:09 PM
SoCal
MuuMuu101 Offline
MuuMuu101  Offline
SoCal
Ideally you'd want to constrain the system to something that is infinitely stiff. I'm not exactly sold on the 3 bolt idea. I'd definitely want one side completely bolted down but I'd support it somewhere in the middle or 3/4 of the way down so when you apply a torque on the other side with a lever arm, you're not also making it a cantilever beam (which I guess the 3 bolt method would help prevent).
And the purpose of the test is "which frame has the best torsional rigidity relative to the others," correct? So if that's the case, you don't need exact numbers so long as all of them are tested and constrained the same on the same rig. Whichever resists the torque to most obviously has the most torsional rigidity.
Re: K frame strength [Re: feets] #1911307
09/12/15 10:10 PM
09/12/15 10:10 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
I've been thinking about this. I don't think the test you propose has much to do with the real world. The K is basically like a sheet of plywood and they all will flex a lot. What's missing is the inner fenders and firewall which combined make a large box that resists flex or twist.
What the K really does is prevent paralelograming of the front subframe. Here is where the stock K looks to be much better than most aftermarket units. Look at all the triangulation in the stocker vs aftermarket.
Just my take on it...
Angry white pureblood male
Re: K frame strength [Re: feets] #1911369
09/12/15 11:48 PM
09/12/15 11:48 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
One thing the stock K member does better than any aftermarket one I've seen is support the LCA inner mounting point. Some of the aftermarket ones are nothing more than a foot of box tubing with some tabs cantilevered off it for the LCA mount. HDK comes to mind, especially in regards to not having a clue what the word parallelograming means.
http://i160.photobucket.com/albums/t164/Freaks-Photos/70%20Dart/K-in-car.jpg
Don't be the exception.
Re: K frame strength [Re: feets] #1911378
09/13/15 12:00 AM
09/13/15 12:00 AM
Los Osos, Ca
CKessel Offline
CKessel  Offline
Los Osos, Ca
Chris, thank you for chiming in on this with Peter, Feets, JCC etc. You and Peter especially since you have been exposed to the test rigs and stuff with current and former employers and can weed through the feces and shinola. I'm interested in this as I'm not a believer of the A/M units as there is not enough cycle time, miles, crappy roads, Dukes Of Hazard imitations etc on them to prove they are worthy of purchasing and using. I know that eventually we will have no choice when nothing else available to us[ hint, hint for someone to make]. I've been working on the 70 k unit that will be going into my 65 and am interested in where worthwhile improvements can be made as I plan to autocross, road course, drag etc the car. Two of the things I've done are: add in 108 spot/plug welds around the k perimeter compared to 37 factory spot welds, box in the strut rod mount area on the backside of the k instead of just using the 2 attachment spots from Ma Mopar. Salivating on this subject fellas!!!!! Keep at it.
Carl Kessel
Re: K frame strength [Re: feets] #1911454
09/13/15 02:05 AM
09/13/15 02:05 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
If they braced the mounts of the K back the crossmember and went with a factory lower control/strut rod arrangement and kept the torsion bars but still use a rack, I'd like it more.
Re: K frame strength [Re: feets] #1911460
09/13/15 02:27 AM
09/13/15 02:27 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Perhaps in this fashion
