stealth heads
#1910650
09/11/15 05:42 PM
09/11/15 05:42 PM
BeavisHQV
so it seems i`m in trouble. wanted to retighten my stealth heads for the first time but ive lost the instructions. so hopefully somebody here has these and can make me a copy or picture. Just need the part with the sequence and specs to retighten the headbolts. PS: i hate me
Re: stealth heads
[Re: BeavisHQV]
#1910688
09/11/15 06:58 PM
09/11/15 06:58 PM
Posts: 75,066 U.S.S.A.
JohnRR
U.S.S.A.
Wouldn't it be the same as a STOCK head ???
Re: stealth heads
[Re: BeavisHQV]
#1910699
09/11/15 07:26 PM
09/11/15 07:26 PM
Posts: 5,163 CT
GTX MATT
CT
If you put ARP lube on them 60 ft lbs, order is the same as stock, start at the center bolt and work your way out
Re: stealth heads
[Re: BeavisHQV]
#1911859
09/13/15 09:28 PM
09/13/15 09:28 PM
Posts: 43,232 Bend,OR USA
Cab_Burge
Start at the center middle bolt and do it, then the bottom two under it and then the top two, work your way front to back in that zigzax order until done
