383 Crank Turn or just Polish #1910298
09/10/15 11:55 PM
09/10/15 11:55 PM
California
P
Plymouth273 Offline OP
P
California
Crank is at the Machinist, which is better just polishing it and staying standard or going .010 on Mains and Rod bearings for a new surface. He said I would be fine with standard but its a 120k motor but well maintained. I have bearings for either application so that is not a concern. Thanks.
Re: 383 Crank Turn or just Polish [Re: Plymouth273] #1910302
09/11/15 12:00 AM
09/11/15 12:00 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
If the machinist says it's good why second guess him. After all it is what he does for a living.shruggy
Re: 383 Crank Turn or just Polish [Re: stumpy] #1910316
09/11/15 12:12 AM
09/11/15 12:12 AM
California
P
P
California
Thats what I'm thinking, but this is a first for me, I usually need them turned without question. Pleasantly surprised by the condition of the engine when I opened it up.
Re: 383 Crank Turn or just Polish [Re: Plymouth273] #1910464
09/11/15 11:55 AM
09/11/15 11:55 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
What is is basing his "it would be fine with Standard" on ?
Has he mocked up the crank in the block and check bearing clearances already with the new bearings and in the resized rods ?
Re: 383 Crank Turn or just Polish [Re: Plymouth273] #1910501
09/11/15 12:56 PM
09/11/15 12:56 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
If it measures fine and isn't scored stick with standard.
