carb recomendation
#1910134
09/10/15 08:29 PM
09/10/15 08:29 PM
Posts: 25 Santa Rosa, Calif
angleiron2
Santa Rosa, Calif
I am just finishing my project street strip 69 dart and looking for a carb recomendation. It has a 446 with 10.5 Ross piston, h beam rods, Indy EZ heads, Proparts headers and a Comp Cams xs290s cam 252/260 exhaust duration a 10 inch Turbo Action med converter with 3.91 gears and MT 295 55 15 tire about 28 inch dia. I was thinking about a Mighty Demon 850 with annular boosters and mechanical secondaries. How does that carb sound? Just doing some bracket racing and some street driving not every day maybe once a week, so mileage isn't important. Oh yeah m1 intake
Re: carb recomendation
[Re: angleiron2]
#1910260
09/10/15 10:56 PM
09/10/15 10:56 PM
Posts: 4,457 Washington
madscientist
Washington
Use a dominator and have it prepped by someone who knows what they are doing. A 750 is WAY too small for your CID and gear.
[Re: angleiron2]
#1910309
09/11/15 12:06 AM
09/11/15 12:06 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I am just finishing my project street strip 69 dart and looking for a carb recomendation. It has a 446 with 10.5 Ross piston, h beam rods, Indy EZ heads, Proparts headers and a Comp Cams xs290s cam 252/260 exhaust duration a 10 inch Turbo Action med converter with 3.91 gears and MT 295 55 15 tire about 28 inch dia. I was thinking about a Mighty Demon 850 with annular boosters and mechanical secondaries. How does that carb sound? Just doing some bracket racing and some street driving not every day maybe once a week, so mileage isn't important. Oh yeah m1 intake It sounds like this is more of a street car.. a smaller carb will produce less power BUT drive nicer on the street... be true to your self and say how much you plan on racing it.. guys love to get on here and say street/strip and might run it once a year on the track... so do you want the power or do you want better drive-ability
[Re: angleiron2]
#1910348
09/11/15 01:10 AM
09/11/15 01:10 AM
Posts: 1,134 Lost in Time
Iowan
Lost in Time
I've got a similar 452 cid 440 with a Holley 9380 850. Excellent throttle response and no over rich on the dyno or at the track.
Have a great day Iowan
"obsolete is neat"
[Re: angleiron2]
#1910470
09/11/15 12:10 PM
09/11/15 12:10 PM
Posts: 12,076 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Everyone has an opinion and they all seem to be different, so here's mine. Bracket racing and street driving would indicate the need for a carb that is dependable, repeatable, with good driveability rather than one that would sacrifice those features in exchange for a few more ponies. So I think that the tune in the carb will be more important to you than the size. Since you are asking for size recommendations, I would guess that you are not an experienced tuner. Find a good tuner and go with his advice as to size, then have him dial it in. If someone wants to just pull a carb out of the box and go, there is so much more to that choice than size. Just look at the number of models available in any given size. But no matter what size or brand of carb you decide to buy, there will be plenty of room for improvement in the tune. Most will be close at wide open, but at idle, low engine speed transitions and cruise any carb will be able to be improved.
Master, again and still
[Re: Cab_Burge]
#1910476
09/11/15 12:23 PM
09/11/15 12:23 PM
BradH
I would not buy or use any 4150 carb. that had annular boosters... x2, certainly not the Demon 850 annular you mentioned for that application. My suggestion: Quick Fuel Q-850 (1.39" v x 1.75" throttle). Saw one for sale on Amazon for under $700 just the other day. I don't know how close the OOB tune really is, but Dom (Thumperdart) has gone through one recently, IIRC, and may have more input on that.
[Re: BradH]
#1910480
09/11/15 12:28 PM
09/11/15 12:28 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
Done a couple and they`re a nice tunable piece for sure w/all of the bells n whistles........
[Re: Thumperdart]
#1910485
09/11/15 12:38 PM
09/11/15 12:38 PM
BradH
I`d get a Quickfuel 950... FWIW, I didn't see your suggestion before I posted mine shortly after you did yours. I agree that the combination described by the OP would work OK w/ the 1.45" v "950", but it's also similar to what I used to have when my car ran 11.0s w/ a Holley "950" HP (1.38" v). That smaller venturi, like the Q-850 has, is super responsive on the street, especially w/ limited gear & converter stall.
[Re: BradH]
#1910491
09/11/15 12:50 PM
09/11/15 12:50 PM
Thumperdart
State of confusion
I`d get a Quickfuel 950... FWIW, I didn't see your suggestion before I posted mine shortly after you did yours. I agree that the combination described by the OP would work OK w/ the 1.45" v "950", but it's also similar to what I used to have when my car ran 11.0s w/ a Holley "950" HP (1.38" v). That smaller venturi, like the Q-850 has, is super responsive on the street, especially w/ limited gear & converter stall. Either Holley or Quickfuel are good pieces to start with and both can be tuned to perfection.......
