Re: Push Button 727 in a street rod #191001
02/14/09 04:08 PM
02/14/09 04:08 PM
Thought I would add my two cents. I built my 33 Plymouth with a cast iron TF behind the 392 (1957). I used the pushbutton assembly out of a 58 Dodge and it worked fine. However, ultimately, I was not happy with the CI TF and swapped in a TH350 out of my 40 Ford. I still have the pushbuttons to work it, although I would prefer to have PARK, which cannot be done with that mechanism. I went inside the tranny and reduced the detent spring force and built some pretty fancy linkage after the cable. I'm just about to switch to a B&M shifter, even though it won't be as cool.
Re: Push Button 727 in a street rod #191002
02/21/09 08:59 PM
02/21/09 08:59 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
So ramman 16248,
have you decided to get that 64 drive train?
I hope so.
Should be a unique set up. Get all you can brackets, pullies, linkage, cables and you will have a nice easy build.
maybe even some day a 6pack to go.
