Front sway bar Bushings issues #1909578
09/09/15 11:11 PM
09/09/15 11:11 PM
SE PA
Paul G Offline OP
Paul G  Offline OP
SE PA
ok, I'll try to describe what I'm experiencing with a brand new set of MOOG front swat bar bushings (silted). It appears that the hole for the sway bar is too high in the bushing in car position. When I mount the sway bar bushing mounting brackets to the 'c' channel brackets that are on the k member the top side of my sway bar is actually touching the edges of the 'c' channel brackets. Tried a second set of bushings with the same results.
has anyone else ran into this issue?
Re: Front sway bar Bushings issues [Re: Paul G] #1909595
09/09/15 11:25 PM
09/09/15 11:25 PM
Ontario, Canada
Stanton Online content
Don't question me!
Stanton  Online Content
Don't question me!
Ontario, Canada
A picture's worth 1000 words !!
Re: Front sway bar Bushings issues [Re: Paul G] #1909778
09/10/15 10:04 AM
09/10/15 10:04 AM
md
mopars4ever Offline
mopars4ever  Offline
md
part number K5241?
Re: Front sway bar Bushings issues [Re: Paul G] #1909926
09/10/15 02:23 PM
09/10/15 02:23 PM
SE PA
Paul G Offline OP
Paul G  Offline OP
SE PA
Yeah, I know... will try to post some shots later today. will verify p/n. thanks
took some pictures but have no idea how to attach them...........
Re: Front sway bar Bushings issues [Re: Paul G] #1910536
09/11/15 02:03 PM
09/11/15 02:03 PM
SE PA
Paul G Offline OP
Paul G  Offline OP
SE PA
Picture added
paul
Re: Front sway bar Bushings issues [Re: Paul G] #1910750
09/11/15 09:31 PM
09/11/15 09:31 PM
North Carolina
469runner Offline
469runner  Offline
North Carolina
Those are crap as you can see. Go on e-bay and check Energy Suspensions bushings or Proform. Much higher quality, and will fit.
Re: Front sway bar Bushings issues [Re: Paul G] #1910753
09/11/15 09:38 PM
09/11/15 09:38 PM
Harriman NY
71GTX471 Offline
71GTX471  Offline
Harriman NY
Are the brackets upside down ?
Re: Front sway bar Bushings issues [Re: Paul G] #1910801
09/11/15 11:06 PM
09/11/15 11:06 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
The guy over on the Road Runner nest gave you the correct info, why not listen to him?
Re: Front sway bar Bushings issues [Re: Paul G] #1910875
09/12/15 12:41 AM
09/12/15 12:41 AM
Shoreline, Washington
72roadrunnergtx Offline
I'll post it here too;
Wrong bushings, correct ones are off-set.
Can only find pics of Poly replacements in the correct config, Ebay auction.
And:
The FACTORY original front sway bar bushing had a profile like this on all ’70-72 B-bodies, the bar is off-set to one end slightly. Any aftermarket bushings having the bar pass through the center of it is NOT correct for this application, bar contact with the bracket (as pictured above) will be the result of its use. The MOOG part is wrong for this application period.
1972 Road Runner GTX 440 6bbl 5-speed
[img]http://72rrgtx.com/carpics/bucket/DSC06730r-1.jpg[/img]
