Re: Aftermarket D-60 covers - All flash, no function?
[Re: 416challenger]
#1908635
09/08/15 02:43 PM
09/08/15 02:43 PM
dartman366
Mt. Vernon, Ohio
I like the aftermarket rear covers due to the cap supports and reinforcement. Not sure if it is really needed, but can't hurt. same here, besides I needed to buy a cover anyways back when I built mine, so I figured why not.
[Re: BradH]
#1908659
09/08/15 03:27 PM
09/08/15 03:27 PM
Posts: 43,373 Bend,OR USA
Cab_Burge
Has anyone on here ever heard of a Dana 60 breaking a cap? I haven't ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) My current car with a Dana 60 has two steel Mark Willaims steel caps on it along with one of those cast aluminum covers with preload bolts in it to hold the steel cap from doing what? ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) This car was raced with a blown B1 motor on alcholol(7.64 ET at 184 MPH) before I traded for it so maybe that is why is had the steel caps, 40 spline gun drilled axles and aluminum 40 spline spool in it when I got it ![work work](/ubbthreads/images/graemlins/custom/work.gif) My thoughts on the cast aluminum covers with the preload bolts is how good can they be ![work work](/ubbthreads/images/graemlins/custom/work.gif) I wouldn't buy one ![twocents twocents](/ubbthreads/images/graemlins/custom/twocents.gif)
[Re: BradH]
#1908665
09/08/15 03:32 PM
09/08/15 03:32 PM
Posts: 13,417 Marion, South Carolina [><]
an8sec70cuda
My Dana just has a chrome cover on it. Bought it new in 2003 and been beating on it ever since w/ no trouble...not even a leak. Ran 10.40s at 3700 lbs for 3 years, then mid 9s at 3800 lbs until the past year or so and it's been running low 9s to hopefully high 8s real soon at 3900 lbs.
FWIW...the only reason I do not have one of the nice aluminum covers is b/c I have a factory gas tank and it won't fit. Do I need it?...evidently not, I just like the looks of them.
[Re: an8sec70cuda]
#1908670
09/08/15 03:41 PM
09/08/15 03:41 PM
BradH
Nothing fancy, just the plain steel cover: I still have an OEM fuel tank, too. Guess there isn't room for a "cool cover" even if I wanted to spend the $$$ on one. OK, I'm good.
[Re: BradH]
#1908671
09/08/15 03:42 PM
09/08/15 03:42 PM
an8sec70cuda
Brad...I was told it would not fit and seems like I remember seeing that posted on here before too. I have never test fit one myself to see.
[Re: Cab_Burge]
#1908674
09/08/15 03:45 PM
09/08/15 03:45 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Has anyone on here ever heard of a Dana 60 breaking a cap? I haven't ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) My current car with a Dana 60 has two steel Mark Willaims steel caps on it along with one of those cast aluminum covers with preload bolts in it to hold the steel cap from doing what? ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) This car was raced with a blown B1 motor on alcholol(7.64 ET at 184 MPH) before I traded for it so maybe that is why is had the steel caps, 40 spline gun drilled axles and aluminum 40 spline spool in it when I got it ![work work](/ubbthreads/images/graemlins/custom/work.gif) My thoughts on the cast aluminum covers with the preload bolts is how good can they be ![work work](/ubbthreads/images/graemlins/custom/work.gif) I wouldn't buy one Yes I have seen a D-60 with a cap broken... but it also had a ring and pinion busted up... so was it the ring and pinion that broke the cap or was it the cap that broke and that broke the ring and pinion... I have no clue ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: an8sec70cuda]
#1908682
09/08/15 03:51 PM
09/08/15 03:51 PM
MR_P_BODY
Brad...I was told it would not fit and seems like I remember seeing that posted on here before too. I have never test fit one myself to see. I have heard the same thing... with a stock tank and a dana its close anyways so my guess it would crash... I know from working in the fuel lab and pulling tanks all the time.. it was close ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: an8sec70cuda]
#1908714
09/08/15 04:18 PM
09/08/15 04:18 PM
Posts: 11,689 W. Kentucky
justinp61
W. Kentucky
Brad...I was told it would not fit and seems like I remember seeing that posted on here before too. I have never test fit one myself to see. My Dart has the rear end moved back 1" with a stock tank and it clears it, maybe 3/8". About the same as the chrome cover.
[Re: justinp61]
#1908719
09/08/15 04:26 PM
09/08/15 04:26 PM
an8sec70cuda
Brad...I was told it would not fit and seems like I remember seeing that posted on here before too. I have never test fit one myself to see. My Dart has the rear end moved back 1" with a stock tank and it clears it, maybe 3/8". About the same as the chrome cover. I don't think it'll fit on a B or E body though.
[Re: an8sec70cuda]
#1908826
09/08/15 07:48 PM
09/08/15 07:48 PM
Posts: 2,475 Sydney,Australia
tex013
Sydney,Australia
my 68 Satellite has a strange S60 with their cast aluminium cover , stock tank . no worries .
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: BradH]
#1908962
09/08/15 11:57 PM
09/08/15 11:57 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
Chrome Direct Connection cover. Strange aluminum bearing caps. Has seen 5.13's, 4.88's, 4.56's, and soon to be installed 4.10's. Twisted axle splines over the years, and broke some ring gear teeth, but never hurt the housing or caps.
[image][/image]
[Re: BradH]
#1908984
09/09/15 12:43 AM
09/09/15 12:43 AM
Posts: 10,563 Rittman Ohio
fourgearsavoy
Rittman Ohio
I've worked on many different rear ends in my life and the Dana in my car has the thinnest caps of any rear I have worked on. I race a 3600# stick car that dead hooks at some tracks so I put studs on the caps and an ultimate 60 support cover just because it makes me feel better when I let the clutch go at 5500. Gus ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: BradH]
#1909069
09/09/15 05:37 AM
09/09/15 05:37 AM
Posts: 625 Deep DEEP SOUTH
LAD 524
Deep DEEP SOUTH
Cast alum cover here, cap supports, stock caps with ARP studs. Getting ready to beat on the Dana soon ![smile smile](/ubbthreads/images/graemlins/custom/smile.gif)
