Aftermarket D-60 covers - All flash, no function? #1908615
09/08/15 02:16 PM
09/08/15 02:16 PM
Val-haul-ass... eventually
BradH Offline OP
BradH  Offline OP
I got my Strange S-60 w/ the standard (cheap) steel differential cover. Any legit reason to consider something else, or is this one of those things people spend $$$ on simply for appearance? Thanks - Brad
Re: Aftermarket D-60 covers - All flash, no function? [Re: BradH] #1908630
09/08/15 02:37 PM
09/08/15 02:37 PM
New Braunfels, TX
416challenger Offline
New Braunfels, TX
I like the aftermarket rear covers due to the cap supports and reinforcement. Not sure if it is really needed, but can't hurt.
Re: Aftermarket D-60 covers - All flash, no function? [Re: 416challenger] #1908635
09/08/15 02:43 PM
09/08/15 02:43 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
same here, besides I needed to buy a cover anyways back when I built mine, so I figured why not.
Re: Aftermarket D-60 covers - All flash, no function? [Re: BradH] #1908655
09/08/15 03:22 PM
09/08/15 03:22 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
If yours is chrome like mine was it'll leak. I replaced it with a heavy steel one.
Re: Aftermarket D-60 covers - All flash, no function? [Re: BradH] #1908659
09/08/15 03:27 PM
09/08/15 03:27 PM
Has anyone on here ever heard of a Dana 60 breaking a cap? I haven't shruggy My current car with a Dana 60 has two steel Mark Willaims steel caps on it along with one of those cast aluminum covers with preload bolts in it to hold the steel cap from doing what? confused shruggy This car was raced with a blown B1 motor on alcholol(7.64 ET at 184 MPH) before I traded for it so maybe that is why is had the steel caps, 40 spline gun drilled axles and aluminum 40 spline spool in it when I got it work My thoughts on the cast aluminum covers with the preload bolts is how good can they be work I wouldn't buy one down twocents
Re: Aftermarket D-60 covers - All flash, no function? [Re: BradH] #1908665
09/08/15 03:32 PM
09/08/15 03:32 PM
an8sec70cuda Offline
My Dana just has a chrome cover on it. Bought it new in 2003 and been beating on it ever since w/ no trouble...not even a leak. Ran 10.40s at 3700 lbs for 3 years, then mid 9s at 3800 lbs until the past year or so and it's been running low 9s to hopefully high 8s real soon at 3900 lbs.
FWIW...the only reason I do not have one of the nice aluminum covers is b/c I have a factory gas tank and it won't fit. Do I need it?...evidently not, I just like the looks of them.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Aftermarket D-60 covers - All flash, no function? [Re: an8sec70cuda] #1908670
09/08/15 03:41 PM
09/08/15 03:41 PM
BradH Offline OP
BradH  Offline OP
Nothing fancy, just the plain steel cover:
I still have an OEM fuel tank, too. Guess there isn't room for a "cool cover" even if I wanted to spend the $$$ on one.
OK, I'm good.
Re: Aftermarket D-60 covers - All flash, no function? [Re: BradH] #1908671
09/08/15 03:42 PM
09/08/15 03:42 PM
Brad...I was told it would not fit and seems like I remember seeing that posted on here before too. I have never test fit one myself to see.
CHIP
Re: Aftermarket D-60 covers - All flash, no function? [Re: Cab_Burge] #1908674
09/08/15 03:45 PM
09/08/15 03:45 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Yes I have seen a D-60 with a cap broken... but it also
had a ring and pinion busted up... so was it the ring and
pinion that broke the cap or was it the cap that broke
and that broke the ring and pinion... I have no clue
wave
Re: Aftermarket D-60 covers - All flash, no function? [Re: an8sec70cuda] #1908682
09/08/15 03:51 PM
09/08/15 03:51 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I have heard the same thing... with a stock tank and
a dana its close anyways so my guess it would crash...
I know from working in the fuel lab and pulling tanks
all the time.. it was close
wave
Re: Aftermarket D-60 covers - All flash, no function? [Re: an8sec70cuda] #1908714
09/08/15 04:18 PM
09/08/15 04:18 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
My Dart has the rear end moved back 1" with a stock tank and it clears it, maybe 3/8". About the same as the chrome cover.
Re: Aftermarket D-60 covers - All flash, no function? [Re: justinp61] #1908719
09/08/15 04:26 PM
09/08/15 04:26 PM
I don't think it'll fit on a B or E body though.
CHIP
Re: Aftermarket D-60 covers - All flash, no function? [Re: an8sec70cuda] #1908720
09/08/15 04:29 PM
09/08/15 04:29 PM
My Duster had the rear end moved forward one inch and the stock Dana steel cover barely cleared the stock gas tank, no way a aftemarket aluminum cover with load bolts would clear twocents shruggy
Re: Aftermarket D-60 covers - All flash, no function? [Re: an8sec70cuda] #1908826
09/08/15 07:48 PM
09/08/15 07:48 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
my 68 Satellite has a strange S60 with their cast aluminium cover , stock tank . no worries .
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Aftermarket D-60 covers - All flash, no function? [Re: BradH] #1908907
09/08/15 10:27 PM
09/08/15 10:27 PM
tulsa ok
U
upnover Offline
upnover  Offline
U
tulsa ok
my cover has the bearing cap supports, if a dana fails thats usually where its gonna fail
Re: Aftermarket D-60 covers - All flash, no function? [Re: BradH] #1908962
09/08/15 11:57 PM
09/08/15 11:57 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
Chrome Direct Connection cover. Strange aluminum bearing caps. Has seen 5.13's, 4.88's, 4.56's, and soon to be installed 4.10's. Twisted axle splines over the years, and broke some ring gear teeth, but never hurt the housing or caps.
[image][/image]
Re: Aftermarket D-60 covers - All flash, no function? [Re: BradH] #1908984
09/09/15 12:43 AM
09/09/15 12:43 AM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I've worked on many different rear ends in my life and the Dana in my car has the thinnest caps of any rear I have worked on.
I race a 3600# stick car that dead hooks at some tracks so I put studs on the caps and an ultimate 60 support cover just because it makes me feel better when I let the clutch go at 5500.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Aftermarket D-60 covers - All flash, no function? [Re: BradH] #1909046
09/09/15 02:47 AM
09/09/15 02:47 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Chrome cover here. Low 9's @3350. Sealed with RTV. When I did an inspection I had to pry it off, never leaks.
Doug
Re: Aftermarket D-60 covers - All flash, no function? [Re: BradH] #1909050
09/09/15 02:59 AM
09/09/15 02:59 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
As far as I know, Dana 60 cover girdles clear all stock fuel tanks EXCEPT the A-body version.
Re: Aftermarket D-60 covers - All flash, no function? [Re: BradH] #1909069
09/09/15 05:37 AM
09/09/15 05:37 AM
Deep DEEP SOUTH
LAD 524 Offline
LAD 524  Offline
Deep DEEP SOUTH
Cast alum cover here, cap supports, stock caps with ARP studs.
Getting ready to beat on the Dana soon smile
