Page 4 of 5 1 2 3 4 5
Re: Small port w8??? [Re: W5DART66] #1907289
09/06/15 02:58 AM
09/06/15 02:58 AM
In a house near you
Street Monkies Offline
In a house near you
I want to bring this post back up. The debate about big flow numbers and big ports. I got some info
Something I read from a guy in the engine masters challenge. He says "You only have so much time to get the air to move, and you need air velocity to move it. If you don't have 400 feet per second minimum at 28 inches of water [ depression ], you are never going to get the air to move, especially at lower rpm." His heads only have a cross-sectional area of 2.3 square inches. The chamber by the way is 37.5 cc. You might ask why so small on the combustion chambers? Well, the combustion chambers are a by product of the ports and bore size, and the ports actually continue past the valve and into the combustion chamber. The chamber has a reason why the way it is because that's the way the port wants it to be. As far as big flow numbers go.. You can have a big flow number head like in this article that's on totalflowproducts that I am sharing. They proved in the article that better flow numbers doesn't mean more power. Actually a head that flowed less made more power. That was because of certain key things that they changed and tested to back up their results. Check it out and you might learn something. I'm one to share and try and learn something new each day. Also flow benches measure cubic feet per minute not velocity. You can easily kill energy in the port by making it too big.. You don't want to live by some is good, more is better, and big is just right because it's not.
http://www.totalflowproducts.com/flow-bench.html
Re: Small port w8??? [Re: W5DART66] #1907952
09/07/15 12:29 PM
09/07/15 12:29 PM
New Smyrna Beach FL
scottb Offline
scottb  Offline
New Smyrna Beach FL
Brett why are you wasting your time arguing with this clown he's not worth your time we all thank you for the R&D you have put into the W8-9 heads and sharing the info with us blow this clown off
Re: Small port w8??? [Re: Street Monkies] #1908297
09/07/15 10:04 PM
09/07/15 10:04 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
these cylinder heads got me 5.70s on pump gas at 3000 pounds. With more to come. Thanks again Brett you're the man.
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: Small port w8??? [Re: W5DART66] #1908473
09/08/15 03:47 AM
09/08/15 03:47 AM
SoCal
Brian Hafliger Offline
SoCal
Originally Posted By W5DART66
Naw just looks strange in that pic.
Might need a set next year to try out some new headers!!
Brian Hafliger
Re: Small port w8??? [Re: WHITEDART] #1909788
09/10/15 10:46 AM
09/10/15 10:46 AM
Earth
Rob C Offline
Rob C  Offline
Earth
Originally Posted By WHITEDART
hey would like to thank brett miller for all his hard work and time he put in these heads.. I took the heads to QMP RACING hear in so cal ..and had them flow this set of small....... brad at qmp was very happy with these number
Ditto with my builder here on the Island who does a lot of "Cup cars" head work. While mine are only the W5 heads, the fellas that flowed the heads we're impressed with the good flow and low swirl stating a really nice and highly efficient port. Damn shame the W5 wasn't up to snuff for more extensive porting!
To make an echo.... Thanks Brett
Re: Small port w8??? [Re: Rob C] #1911453
09/13/15 02:05 AM
09/13/15 02:05 AM
Victoria, Australia
Ian Offline
Ian  Offline
Victoria, Australia
some pics of my junkie w8 s they go 400 cfm with the intake on ,remember we should not hang it on someone for trying something different with the heads ,there is many ways to make hp . [img:center][/img] [img:center][/img]
1.37 60 ft [email]6.0@113[/email] [email]9.57@141[/email] 408 glide 3550lbs
new video http://www.youtube.com/watch?feature=player_embedded&v=Xvq3ZObywQE
Re: Small port w8??? [Re: Ian] #1911505
09/13/15 07:56 AM
09/13/15 07:56 AM
western PA
stevet340 Offline
stevet340  Offline
western PA
Very nice W8 port Ian! up The short side radius looks awesome! I'm sure some will chime in the throat area appears way too small, but from what I can see it looks like a very well thought out and professionally done max effort port. I'd also venture to say it was/is a hand finished port. Thanks for sharing. wave
Re: Small port w8??? [Re: stevet340] #1912086
09/14/15 10:11 AM
09/14/15 10:11 AM
Victoria, Australia
Ian Offline
Ian  Offline
Victoria, Australia
thanks steve,should work well with this set up lol [img:center][/img]
Re: Small port w8??? [Re: W5DART66] #1912128
09/14/15 11:46 AM
09/14/15 11:46 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
guess you're saying my 4150 carb is too small laugh2 Any eta on that project getting completed? Should be veerryy interesting!
Re: Small port w8??? [Re: Ian] #1912689
09/15/15 12:12 AM
09/15/15 12:12 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Looks like a very nice truck port. Who did you get the heads from.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Small port w8??? [Re: 1967dartgt] #1912797
09/15/15 04:06 AM
09/15/15 04:06 AM
Victoria, Australia
Ian Offline
Ian  Offline
Victoria, Australia
i may run it like this with the single and nos my tunes have worked very well so far ,the sheet metal and nitrous will be the crazy deal. the heads are patterson racing and have had a some work done over here by a top pro stock team engine builder.E T A is slow due to sudden setbacks like the r block had a 5 inch crack in the new block its been hard to sauce another r3 but by xmas here with luck. [img:center][/img]
Re: Small port w8??? [Re: Ian] #1912840
09/15/15 09:54 AM
09/15/15 09:54 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
What size valves are you running?
Re: Small port w8??? [Re: W5DART66] #1912863
09/15/15 10:41 AM
09/15/15 10:41 AM
Victoria, Australia
Ian Offline
Ian  Offline
Victoria, Australia
2,25 1.55
Re: Small port w8??? [Re: W5DART66] #1912867
09/15/15 10:49 AM
09/15/15 10:49 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Wow they flow quite a bit more then my Patterson racing w8's. What valve angle are those?
Re: Small port w8??? [Re: W5DART66] #1912870
09/15/15 11:03 AM
09/15/15 11:03 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Cracked R3..... now that would suck. Hard enough procuring stuff like that over here. I need go to a 4500 on mine, but all in good time.
Re: Small port w8??? [Re: J_BODY] #1912932
09/15/15 12:04 PM
09/15/15 12:04 PM
Victoria, Australia
Ian Offline
Ian  Offline
Victoria, Australia
yep parts are like rocking horse ship,they say 30 hp pick up on a change of flange .
Re: Small port w8??? [Re: 1967dartgt] #1912937
09/15/15 12:13 PM
09/15/15 12:13 PM
Victoria, Australia
Ian Offline
Ian  Offline
Victoria, Australia
52 in ex 45 what cc was your heads
Re: Small port w8??? [Re: W5DART66] #1913603
09/16/15 12:16 PM
09/16/15 12:16 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
I was meaning 15°, 13° or what ever they are. They are 320cc. These are from the pro stock truck days when they were involved in racing those
Re: Small port w8??? [Re: 1967dartgt] #1914082
09/16/15 10:50 PM
09/16/15 10:50 PM
Victoria, Australia
Ian Offline
Ian  Offline
Victoria, Australia
10 degree with 300 cc runner 36 cc chamber
Re: Small port w8??? [Re: Ian] #1914108
09/16/15 11:26 PM
09/16/15 11:26 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
Looks like you're going to need some creative spacers in order for that intake to work. However nice looking stuff.. what are your plans, am I missing the flow numbers . 400cfm does not seem to be too difficult to achieve with these cylinder heads..
