W5 422ci question #1907615
09/06/15 08:24 PM
09/06/15 08:24 PM
Louisville, Ky.
Mojoluv Offline OP
Mojoluv  Offline OP
Louisville, Ky.
My friend is putting his 422 W5 headed engine together. He is using a Moroso deep pan with baffles. Does this engine need a windage tray and what does it hurt if he dont have one?
Re: W5 422ci question [Re: Mojoluv] #1907628
09/06/15 08:51 PM
09/06/15 08:51 PM
Louisiana
Bignick Offline
Bignick  Offline
Louisiana
Won't hurt anything. May not make max HP but no issues.
70 Duster 422"eddy head smallblock, PTC built 904, PTC 8" conveter, Dana 60 4.56 gear
Re: W5 422ci question [Re: Bignick] #1907643
09/06/15 09:23 PM
09/06/15 09:23 PM
Louisville, Ky.
Mojoluv Offline OP
Mojoluv  Offline OP
Louisville, Ky.
Thanks for the reply. He already has the pan on the engine and somebody told him that he messed up not putting a tray in it. He wasnt sure whether it would be worth it or not to have to pull the pan and all that mess to put one in.
Re: W5 422ci question [Re: Mojoluv] #1907651
09/06/15 09:37 PM
09/06/15 09:37 PM
MR_P_BODY Offline
MR_P_BODY  Offline
A GOOD oil pan you dont need the windage tray... but it
will help with that pan... might need to do some work om
the tray also... if I run a real deep pan I dont run a
tray but a scraper helps all the time
wave
Re: W5 422ci question [Re: Mojoluv] #1909794
09/10/15 10:52 AM
09/10/15 10:52 AM
Earth
Rob C Offline
Rob C  Offline
Earth
Exactly! If the pan is deep enough, no windbags tray is needed. FWIW, the factory tray isn't going to help. It is to shallow to the crank, move it downwards if you install it. But a deep pan will do. A scraper is an excellent idea. A bit of a pain to get it just the way you want it, but what else is new with this kind of stuff?
Re: W5 422ci question [Re: Mojoluv] #1910264
09/10/15 11:00 PM
09/10/15 11:00 PM
Washington
madscientist Offline
Washington
Rather than guess at what you are doing, call Ishihira-
Johnson and talk to Kevin. You can learn more from him in 15 minutes on the phone than you ever will on a forum. Take notes because he will flood you with information.
May have the spelling wrong but just google crank scrapers and it comes up.
