Re: Real world weight loss program and it` cost..........
[Re: fullmetaljacket]
#1907666
09/06/15 10:15 PM
09/06/15 10:15 PM
Thumperdart
State of confusion
That`s my concern and you are correct about the HS`s being extra bulky but was always told the comp. stainless or similar rockers couldn`t handle roller high spring pressures.......
[Re: Thumperdart]
#1907667
09/06/15 10:17 PM
09/06/15 10:17 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Thankxx, I think the width was an issue also but not 100% sure on that....... I remember some guys doubling up the gaskets to clear rockers BUT I forget what rockers on BB... on my covers I had to mill the outer(lower edge) to clear my springs.. I am using 1.65 OD and things were hitting before I milled the lip... plus I had to clearance the gasket.. I use the MP silicone over a steel core.. life time ones)... all extra work to run that diameter spring... even the 1.55" OD spring was gonna hit or be very close ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: MR_P_BODY]
#1907680
09/06/15 10:29 PM
09/06/15 10:29 PM
Thumperdart
State of confusion
Now this is goin where I have no desire to go so I think the mp`s will stay on at this point.......
[Re: Thumperdart]
#1907688
09/06/15 10:35 PM
09/06/15 10:35 PM
MR_P_BODY
Now this is goin where I have no desire to go so I think the mp`s will stay on at this point....... SB and BB are 2 different worlds... you stock style covers (with the out side lip) are the difference.. I HAVE to use the reverse lip covers.. and that in ts self creates issues that has to be dealt with... there is NO WAY I can use a stock style cove on my engines(any of my SBs)
[Re: MR_P_BODY]
#1907731
09/06/15 11:11 PM
09/06/15 11:11 PM
Thumperdart
State of confusion
What is a reverse lip...........have no clue?
[Re: Thumperdart]
#1907743
09/06/15 11:31 PM
09/06/15 11:31 PM
MR_P_BODY
What is a reverse lip...........have no clue? Just like it says... the lip on your covers goes out and you can use a 3/4" long bolt/or stud... on mine the lip is turned inside(this moves the vertical wall out farther) but I have to use a 5" long stud to come up to the top.. here is another pic.. if you see you have a lip of the cover that is outside that I dont have(thats where you bolt yours on) ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: Thumperdart]
#1907753
09/06/15 11:52 PM
09/06/15 11:52 PM
Posts: 1,895 Spahn Ranch
RMCHRGR
Spahn Ranch
These are reverse lip wide valve covers for the W series heads. I tried to do what FMJ did on some old Moroso valve covers but they didn't come out so great. Had a hard time tapping the letters down, the metal gets work hardened. Too much work to get them looking decent and using filler would add weight back. Just went back to the cast ones.
'71 Duster '72 Challenger '17 Ram 1500
[Re: MR_P_BODY]
#1907895
09/07/15 10:14 AM
09/07/15 10:14 AM
Posts: 2,709 NJ central
Scamp408
NJ central
What is a reverse lip...........have no clue? Just like it says... the lip on your covers goes out and you can use a 3/4" long bolt/or stud... on mine the lip is turned inside(this moves the vertical wall out farther) but I have to use a 5" long stud to come up to the top.. here is another pic.. if you see you have a lip of the cover that is outside that I dont have(thats where you bolt yours on) Hey MR P you wouldnt happen to have a extra stud kit for the wide covers for sale would ya?
[Re: MR_P_BODY]
#1907978
09/07/15 01:09 PM
09/07/15 01:09 PM
Thumperdart
State of confusion
What is a reverse lip...........have no clue? Just like it says... the lip on your covers goes out and you can use a 3/4" long bolt/or stud... on mine the lip is turned inside(this moves the vertical wall out farther) but I have to use a 5" long stud to come up to the top.. here is another pic.. if you see you have a lip of the cover that is outside that I dont have(thats where you bolt yours on) I see and like that deal WAY better and would think it seals better as well....... ![thumbs thumbs](/ubbthreads/images/graemlins/custom/thumbs.gif) Thankxx David for that info and I`m still on the fence here but will figure something out soon.
[Re: Scamp408]
#1908228
09/07/15 08:09 PM
09/07/15 08:09 PM
MR_P_BODY
What is a reverse lip...........have no clue? Just like it says... the lip on your covers goes out and you can use a 3/4" long bolt/or stud... on mine the lip is turned inside(this moves the vertical wall out farther) but I have to use a 5" long stud to come up to the top.. here is another pic.. if you see you have a lip of the cover that is outside that I dont have(thats where you bolt yours on) Hey MR P you wouldnt happen to have a extra stud kit for the wide covers for sale would ya? No.. none for sale.. I have part of a set.. but I'm keeping them ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
