What sparkplug for 440 source heads #1906261
09/04/15 12:53 PM
09/04/15 12:53 PM
Oklahoma City, OK
Dave64 Offline OP
Dave64  Offline OP
Oklahoma City, OK
Trying to help get info on what plug to use with a set of 440 source big block heads. What do you run? What is the part number for Champion and Autolite? Thanks for the help in advance!
Re: What sparkplug for 440 source heads [Re: Dave64] #1906279
09/04/15 01:26 PM
09/04/15 01:26 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
try some autolite 3924's. easy to come by and you can move up or down from there.
Re: What sparkplug for 440 source heads [Re: Dave64] #1906282
09/04/15 01:27 PM
09/04/15 01:27 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
What combo and compression? I run only NGK`s cos they`re easier to get a full reading on and live well street/strip and for my 12.1.1 comp. 470 w/alum heads I run a # 7 or 8. 7`s stay a bit cleaner and 8`s are colder for full boogie blasts if engine temps are above 180-190.
Re: What sparkplug for 440 source heads [Re: Dave64] #1906283
09/04/15 01:27 PM
09/04/15 01:27 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Need more info.. street or strip, compression and what
fuel.... but autolite 3924 is a decent number.. thats
the full strap.. they offer the race version also which
starts with a "R" which is a short strap
wave
Re: What sparkplug for 440 source heads [Re: MR_P_BODY] #1906303
09/04/15 02:04 PM
09/04/15 02:04 PM
Oklahoma City, OK
Dave64 Offline OP
Dave64  Offline OP
Oklahoma City, OK
Its probably in the 9to1 area just street strip deal but didn't have a clue on the part number since he had 440 source heads. My friend likes champ and autolite. Thanks for your help!!!
Re: What sparkplug for 440 source heads [Re: Dave64] #1906330
09/04/15 02:45 PM
09/04/15 02:45 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Maybe a 12yc champion then...............
Re: What sparkplug for 440 source heads [Re: Dave64] #1906702
09/05/15 02:39 AM
09/05/15 02:39 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
For my 10:1 compression street car with Stealth Heads, these seen to work good:
NGK #2756 plugs (Plug Part # BKR6E-11) which is a 6 Heat range.
The Plug part # breaks down as:
BK = 14mm thread, 5/8" Hex ISO Type (shorter ceramic part)
R = Resistor Plug.
6 = Heat Range.
E = 3/4" Thread Reach.
-11 = Spark Plug Gap of 0.044"
The #2 plug is pretty close to the inner fender on my Coronet, so I also use the special Snap-On spark plug tool:
https://store.snapon.com/Hand-Sockets-So...ex-P644223.aspx
Re: What sparkplug for 440 source heads [Re: Dave64] #1907079
09/05/15 08:01 PM
09/05/15 08:01 PM
Long Island, NY
shocktrp Offline
shocktrp  Offline
Long Island, NY
Just had this same problem - car was running like crap.
Last owner apparently couldn't figure it out & first mechanic also had no idea.
I finally found a guy who knows these cars - he said to use RC12YC because they are longer than the stock ones.
(The 2nd digit "C" is different from the stock part # which I can't remember off the top of my head right now.)
Problem went away immediately.
Re: What sparkplug for 440 source heads [Re: shocktrp] #1907237
09/06/15 12:28 AM
09/06/15 12:28 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
I used Champion RC12YC in mine and they worked perfectly!
Re: What sparkplug for 440 source heads [Re: GY3] #1907264
09/06/15 01:47 AM
09/06/15 01:47 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
When I crossed referenced the RC12YC to NGK it lists several heat range 5 and 6 plugs, including the BKR6E that I'm using, so I think the heads like the hotter spark plugs. I orginally had cooler "8" heat range plugs and they fowled when the weather got coolder, that is why I went to the hotter plugs.
Re: What sparkplug for 440 source heads [Re: Dave64] #1907487
09/06/15 03:31 PM
09/06/15 03:31 PM
For a low compression pump gas motor with those heads i would start with either the Champion RC12YC or the nextstep hotter one, if champion offers them thumbs On Auotlites thier # 3325 will probaly work okay also scope
Re: What sparkplug for 440 source heads [Re: Cab_Burge] #1910337
09/11/15 12:44 AM
09/11/15 12:44 AM
Oklahoma City, OK
Dave64 Offline OP
Dave64  Offline OP
Oklahoma City, OK
Thanks everyone...
