Water Pump Restoration #1904472
09/01/15 10:08 PM
09/01/15 10:08 PM
MN
Droop69 Offline OP
Droop69  Offline OP
MN
I have the original water pump (big block) for my car that was removed back in the 80's because it was leaking. I would like to put it back on the car, because it is original and the date code is correct.
Does anybody know a source to get these rebuilt/restored?
Re: Water Pump Restoration [Re: Droop69] #1904535
09/01/15 11:12 PM
09/01/15 11:12 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
There is a shop here in Sacramento that does it but it's not cheap. I think it was $65 per pump. You also have to ask them to not paint them. They use the old impeller too.
Re: Water Pump Restoration [Re: Morty426] #1904668
09/02/15 02:23 AM
09/02/15 02:23 AM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
Re: Water Pump Restoration [Re: jlatessa] #1904733
09/02/15 10:27 AM
09/02/15 10:27 AM
MN
Droop69 Offline OP
Droop69  Offline OP
MN
Thanks for the info guys. If I can find that seal, I think I will try and rebuild it myself.
Re: Water Pump Restoration [Re: Droop69] #1904889
09/02/15 01:52 PM
09/02/15 01:52 PM
Star Idaho
67vertman Offline
67vertman  Offline
Star Idaho
Try Gary, He can either rebuild it for you or sell you a kit.
Gary Nelson
10079 Highway 50 E. Unit C
Carson City, Nevada 89706
Phone: 775 851-1420. 7 days, 9am to 7pm, PST
E-mail: garythepartsdoc@glnelson.com
My Monster are real!
Living within your means makes life pretty easy.
Re: Water Pump Restoration [Re: Droop69] #1904894
09/02/15 01:57 PM
09/02/15 01:57 PM
Connecticut
1972CudaV21 Offline
1972CudaV21  Offline
Connecticut
Is there a source for someone that rebuilds small block water pumps?
China is the enemy.
Re: Water Pump Restoration [Re: 67vertman] #1904953
09/02/15 03:14 PM
09/02/15 03:14 PM
MN
Droop69 Offline OP
Droop69  Offline OP
MN
Thanks for the info. I am having a hard time finding a kit around here.
I wish that guy would have put the part number of the kit he used on the rebuild he did.
Re: Water Pump Restoration [Re: Droop69] #1906210
09/04/15 11:07 AM
09/04/15 11:07 AM
resq302
resq302
I agree. I wish I knew the part number for that as well. I have our original dated water pump waiting to be rebuilt in my crawl space.
Re: Water Pump Restoration [Re: Droop69] #1910077
09/10/15 06:31 PM
09/10/15 06:31 PM
St. Louis
I
Imrare Offline
Imrare  Offline
I
St. Louis
Arthur Gould Rebuilders, did my big and small block pump.
arthurgouldrebuilders.com/
