big block E street heads and hyd roller cam question #1903715
09/01/15 08:17 AM
09/01/15 08:17 AM
Australia
Teamx Offline OP
Teamx  Offline OP
Australia
Could anyone advise if it would be ok to run a small hyd roller cam with 150 on the seat springs on the E street Edelbrock heads.
It says in the instuctions not for use with roller cams I think because the valve seats are made of a lesser different material.
I would like to run theese heads as they have the smaller 75cc chambers and that will get the comp where it needs to be. Thanks
Re: big block E street heads and hyd roller cam question [Re: Teamx] #1904031
09/01/15 01:41 PM
09/01/15 01:41 PM
AndyF Offline
AndyF  Offline
There is a 75cc Performer RPM head that is designed to work with hyd rollers. It costs a little bit more but I think that is becuase is comes with higher quality valves and seats.
Re: big block E street heads and hyd roller cam question [Re: Teamx] #1904120
09/01/15 02:58 PM
09/01/15 02:58 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I have the small block chevy E street heads and you could not find a spring that would support a roller. The springs are small and light, .550 lift is about all mine will support.
I know this is apples to oranges but I would check the springs.
Re: big block E street heads and hyd roller cam question [Re: Teamx] #1904157
09/01/15 03:34 PM
09/01/15 03:34 PM
AndyF Offline
AndyF  Offline
Do you already have the E-street heads or are you trying to decide what to buy? Edelbrock has heads for hyd roller springs.
http://www.edelbrock.com/automotive/mc/cylinder-heads/chrysler/performer-rpm-bb.shtml
Re: big block E street heads and hyd roller cam question [Re: AndyF] #1905526
09/03/15 07:36 AM
09/03/15 07:36 AM
Australia
Teamx Offline OP
Teamx  Offline OP
Australia
Thanks for the help,didnt know they made RPMS with a 75cc chamber will go with them.
Re: big block E street heads and hyd roller cam question [Re: Teamx] #1905668
09/03/15 01:50 PM
09/03/15 01:50 PM
AndyF Offline
AndyF  Offline
Yeah, hard to stay on top of all the parts that come out. I didn't know they were making 75cc RPM heads either until just recently when I saw a set at the engine builder. They worked pretty good on the 383 stroker that he had on the dyno.
Re: big block E street heads and hyd roller cam question [Re: Teamx] #1909795
09/10/15 10:59 AM
09/10/15 10:59 AM
Earth
Rob C Offline
Rob C  Offline
Earth
These would be good for low compression engines like the 400.
