Un-able to find motor mounts #1902308
08/30/15 09:42 AM
08/30/15 09:42 AM
Ontario, canada
Mopar2ya Offline OP
Mopar2ya  Offline OP
Ontario, canada
I have a 66 B'Cuda and am unable to find motor mounts for a V8, I called Chrysler and they said no longer available any idea's where I could get any? Or know of any that will work? Thanks
Re: Un-able to find motor mounts [Re: Mopar2ya] #1902314
08/30/15 10:09 AM
08/30/15 10:09 AM
IN
ahy Offline
ahy  Offline
IN
Schumacher can probably fix you up. I run their poly mounts with good result. Through bolt or interlocking on the driver side and regular on the right.
You could probably find a set at a parts store but quality of new rubber replacements is often pretty bad. I'd go poly.
http://www.engine-swaps.com/Pages/Products.html
Re: Un-able to find motor mounts [Re: Mopar2ya] #1902317
08/30/15 10:18 AM
08/30/15 10:18 AM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
Click
https://www.rockauto.com/catalog/raframecatalog.php
The go to Plymouth>1966>Barracuda>4.7(273)>engine>motor mount
It shows two brands of mounts in stock
Re: Un-able to find motor mounts [Re: Mopar2ya] #1902399
08/30/15 01:08 PM
08/30/15 01:08 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Are you talking about the rubber part or the metal bracket?
Don't be the exception.
Re: Un-able to find motor mounts [Re: Mopar2ya] #1902764
08/30/15 10:49 PM
08/30/15 10:49 PM
I've seen em on FABO and likely www.slantsix.org someone there would have em but for sure on FABO FYI the /6 insulators are the same, you (as you know) need the metal brackets
Re: Un-able to find motor mounts [Re: Mopar2ya] #1902904
08/31/15 01:11 AM
08/31/15 01:11 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Same as slant. I went through this in the early 1980s. No book showed 273 mounts, but they had pics in the back. The correct pic indicated slant. Looked exactly like what was on the car.
Re: Un-able to find motor mounts [Re: Supercuda] #1903209
08/31/15 03:48 PM
08/31/15 03:48 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Agreed , and who calls Chrysler looking for parts for a 50 yr old car expecting them to have them still ?
Re: Un-able to find motor mounts [Re: JohnRR] #1903421
08/31/15 08:17 PM
08/31/15 08:17 PM
Las Vegas
JeffC Offline
JeffC  Offline
Las Vegas
You'd be surprised I get calls all the time for old stuff.
Re: Un-able to find motor mounts [Re: JeffC] #1903461
08/31/15 09:18 PM
08/31/15 09:18 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
You work at a mopar dealer?
From like 1978-1986 or so I was buying NOS parts from a long time local Dodge dealer that was directly across from where I worked for 8 years all in a effort to restore a 71 challenger. I didn't have clue then, never did finish the car and sold many NOS parts to go drag racing. I know better...now. whiney
Harry to parts manager used to put some of my larger parts on lay away. Once I got it paid off I got to take it home, like one time I remember buying a new 71 challenger grill from the dealer like that. Every Fri I went into the dealer and paid them for parts for years. Couple of my friends worked there too as mechanics. Those were the days as I just pulled into the servive building and parked in a MT bay inside next to my buddy who worked there. I also knew the owners as they lived right around the corner from the dealership.
Re: Un-able to find motor mounts [Re: Mopar2ya] #1903484
08/31/15 09:49 PM
08/31/15 09:49 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Re: Un-able to find motor mounts [Re: Mopar2ya] #1903486
08/31/15 09:50 PM
08/31/15 09:50 PM
md
mopars4ever Offline
mopars4ever  Offline
md
jacks auto parts has them
Re: Un-able to find motor mounts [Re: Mopar2ya] #1903488
08/31/15 09:51 PM
08/31/15 09:51 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Re: Un-able to find motor mounts [Re: Mopar2ya] #1903490
08/31/15 09:55 PM
08/31/15 09:55 PM
md
mopars4ever Offline
mopars4ever  Offline
md
and some stuff you can still get
Re: Un-able to find motor mounts [Re: Mopar2ya] #1903491
08/31/15 09:57 PM
08/31/15 09:57 PM
md
mopars4ever Offline
mopars4ever  Offline
md
mopar part number is different, don`t what is the difference is though
