Hi Joe,
Here is the information for you to test your two switches. Hope this helps.
![](http://i248.photobucket.com/albums/gg169/Slotts/Moparts/FSM%202864014_zpsqu1ofyfv.jpg)
High Speed Position:B to F1 (-28 Ohms {Resistance Through Switch Resistor})
A to F1 (-28 Ohms {Resistance Through Switch Resistor})
B to A (0 Ohms)
F2 to Chassis Ground (0 Ohms)
Medium Speed Position:B to F1 (-10 Ohms {Resistance Only Through Dash Harness Brown* Wire via R1})
A to F1 (-10 Ohms {Resistance Only Through Dash Harness Brown* Wire via R1})
B to A (0 Ohms)
F2 to Chassis Ground 0 Ohms
Low Speed Position:B to F1 (0 Ohms)
A to F1 (0 Ohms)
B to A (0 Ohms)
OFF position:B to P (0 Ohms)
A to F2 (0 Ohms)
F1 to Chassis Ground (0 Ohms)
Internal Circuit Breaker:B to B/U (Always 0 Ohms Regardless of Speed Selection or Off)
