205 70 14 is just about exact with a .3 more section width and .1 less tread width, but the exact heigth. I use Summit's site when doing this kind of research, they show tire specs and carry Coker so I can get the specs on the old rating and then I can use the search by product and start selecting things (ie: tires, 14 inch, radial, heigth, etc...) until I get to what I think I want and then look at the specs on it and adjust up or down if necessary.
http://www.summitracing.com/parts/cok-54660http://www.summitracing.com/parts/bfg-37157One thing to keep in mind is that tire brands differ slightly sometimes in specs on the same size tire but it will be close enough not to really matter.
