Re: RPM rust preventer
[Re: mikemee1331]
#1900493
08/27/15 04:29 PM
08/27/15 04:29 PM
Posts: 2,092 New Mexico
JMCFAN
New Mexico
Stuff I used it on still looks great!
68 Charger 383/ AT Green/Green VT 70 Roadrunner 383/4sp Purple/Black VT
[Re: Morty426]
#1901698
08/29/15 08:50 AM
08/29/15 08:50 AM
Posts: 4,154 bethlehem pa
mikemee1331
bethlehem pa
I'm very happy with how it works but it takes more than advertised in my experience. more initial product or coats?
[Re: mikemee1331]
#1901744
08/29/15 11:12 AM
08/29/15 11:12 AM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
I'm very happy with how it works but it takes more than advertised in my experience. more initial product or coats? Supposedly one is good enough for one car. I've used two for my restoration. I'm sure some times I was putting it on too thick, but I really think enough for one car is a little bit of a stretch. Love the product by the way.
[Re: Morty426]
#1902155
08/29/15 11:35 PM
08/29/15 11:35 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
I just read through the test results. Seems like pretty sturdy and resilient stuff.
anyone have any real world experience of the product NOT working as advertised?
And too bad you have to heat the part to brush on the product. RPM needs to create a similar product that comes in a spray solution so you can spray it into nooks and crannies of car body cavities where you don't get paint applied.
I need to do something to my 06 Ram 2500 to prevent the sheet metal from rusting away, and I need to do it before any rust even starts!
**Photobucket sucks**
[Re: mikemee1331]
#1902348
08/30/15 11:27 AM
08/30/15 11:27 AM
Morty426
Sacramento CA
i asked cause i have to replace my master cylinder and they are SO nice when you get them but in a couple of year exposed to humidity and dripped brake fluid, well you all know! Depending on the year the MC has a unique plating that is not very rust proof. Check with MasterShake340 as to what it is since I cannot remember off the top of my head. Had some plated that I did not protect with RPM and they rusted up pretty quick. The plating shop had mercy on me when I re did them. Put RPM on the and they have looked great for 4 years now.
[Re: Morty426]
#1902441
08/30/15 02:24 PM
08/30/15 02:24 PM
Posts: 1,043 Motown, Mi
PAULS_340
Motown, Mi
This stuff works great but when using a heat gun it melts every brush I've used ! Maybe I can heat the part with the Heatgun and then spread the rpm with a warm hairdryer.
Still looking for LM29H1B415501, '71 Demon 340
[Re: PAULS_340]
#1902492
08/30/15 03:58 PM
08/30/15 03:58 PM
Posts: 1,272 Northern Calyfornua
Sxrxrnr
Northern Calyfornua
This stuff works great but when using a heat gun it melts every brush I've used ! Maybe I can heat the part with the Heatgun and then spread the rpm with a warm hairdryer. I heat the item that I am using it on by first warming in the sun. I then warm further with a heat gun. Only then do I place my brush into the RPM container loading it with the product. Then just like applying paint spread it about. Not my brush, nor any animals were hurt doing in this way. Just did a new master cylinder last month,,,so far looks fine. Will say that using the product you might experience a slight dulling of the native metallic sheen of the original cast iron. Has been my experience, but overall a better outcome than anything else I've used.
[Re: Sxrxrnr]
#1902503
08/30/15 04:31 PM
08/30/15 04:31 PM
mikemee1331
bethlehem pa
This stuff works great but when using a heat gun it melts every brush I've used ! Maybe I can heat the part with the Heatgun and then spread the rpm with a warm hairdryer. I heat the item that I am using it on by first warming in the sun. I then warm further with a heat gun. Only then do I place my brush into the RPM container loading it with the product. Then just like applying paint spread it about. Not my brush, nor any animals were hurt doing in this way. Just did a new master cylinder last month,,,so far looks fine. Will say that using the product you might experience a slight dulling of the native metallic sheen of the original cast iron. Has been my experience, but overall a better outcome than anything else I've used. do you have to do it a side at a time or can you heat sides and keep going? is it affected by by 'over-lap' meaning the dullness you mentioned look duller when you over-lap?
[Re: mikemee1331]
#1903200
08/31/15 03:37 PM
08/31/15 03:37 PM
Sxrxrnr
Northern Calyfornua
Leave it sun, then heat up the whole item additionally with heat gun, then rather quickly paint the whole item. Does not have to be too hot,,,would be good if RPM would suggest range of appropriate temperatures that one could test with one of those laser heat temp guns.
I would not overheat a MC as could be possible to damage seals I suppose. Some heat guns can generate a very high temp.
If you install MC and other underwood items, likely a drive of vehicle would heat up to sufficient temperature to make RPM happy.
Final finish will always be a bit duller than natural glint,,,,somewhat as a clear coat,,,not bad just a bit different.
