Come to find out an Imperial 28 radiator will not fit my 73 Cornet wagon. Will a Charger, or do I need another B Body wagon? The " book" lists some BB wagons had 26, and some 28. I need a 3 core 28. What should I look for as far as OEM fitting?
According to the '73 FSM, there are 3 possible rads for the B body 400 (except police) engine.
-- 26" for non-air/max cooling, #3673961, 16 qt system capacity
-- 28" for air, #3673947, 17 qt system capacity
-- 28" for max cooling, #3673953, 18 qt system capacity
I
assume the 17qt 28" is 2 core, and the 18qt is 3 core, but as you can see, it does not specify.
You said you have the trailer towing package, I think that would give the max cooling rad.
Hope this helps.
