Excessive play in the steering coupler spline
#1898817
08/25/15 02:05 AM
08/25/15 02:05 AM
Posts: 7,489 Minnesota
Hemi_Joel
Minnesota
On a 67 GTX with power steering, I noticed excessive play in the steering wheel. With a little more investigation I see that there is slop where the steering column couples to the splines of the steering box. What is the usual fix for this?
Thanks, Joel
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
Re: Excessive play in the steering coupler spline
[Re: General 68]
#1899011
08/25/15 01:15 PM
08/25/15 01:15 PM
RapidRobert
What General said, & if it is bad enough to be dealt with, then no choice but to pull the column & open the coupler
[Re: Hemi_Joel]
#1899248
08/25/15 06:32 PM
08/25/15 06:32 PM
Posts: 182 Tipp City, Ohio
Backfire
Tipp City, Ohio
If I read your question correctly, it is the splines in the coupling that are worn out. probably from rust. only fix I know is to get a new one.
'68 Charger R\T
[Re: Hemi_Joel]
#1899334
08/25/15 09:05 PM
08/25/15 09:05 PM
Hemi_Joel
Minnesota
Thanks for the replies. The slop that I am seeing is actually in the splines between the shaft of the steering box and the inside diameter of the coupler. Is a new coupler available somewhere?
[Re: Hemi_Joel]
#1899812
08/26/15 03:41 PM
08/26/15 03:41 PM
Posts: 25,784 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Thanks for the replies. The slop that I am seeing is actually in the splines between the shaft of the steering box and the inside diameter of the coupler. Is the large roll pin that secures the coupler in place?
[Re: Hemi_Joel]
#1899965
08/26/15 08:49 PM
08/26/15 08:49 PM
Posts: 566 WA
tman
WA
