Re: replacing turn single switch: brake lights inop
[Re: dynamite]
#1899492
08/26/15 12:14 AM
08/26/15 12:14 AM
RapidRobert
What Pynzo said, at least confirm it is the TS switch assy. seperate the dangling brake/ts connector under the column & in the column half with the stalk in neutral there should be continuity between the white wire which is the "hot in" wire from the brake pedal switch and (2) "out" wires to the large filaments in the rear 1157 bulbs. www.mymopar.com will have the colors for you. If you ain't got that then you know what is coming next. Always a good idea (no matter what) to pull a batt cable before switching the VOM to ohms scale
[Re: smos001]
#1899565
08/26/15 02:30 AM
08/26/15 02:30 AM
RapidRobert
I assume that the brake lights use the same brown and green wires going out to the 1157 bulbs as the turn signal? yes same wires/large filaments in the 1157's & brown & green wires sounds right iirc
