Page 1 of 4 1 2 3 4
whats the coldest temp you'd start your car at? #189810
01/10/09 07:51 PM
01/10/09 07:51 PM
the boonies
aarcuda Offline OP
aarcuda  Offline OP
the boonies
i have 20w50 oil in mine and i decided 45 was too cold....
Re: whats the coldest temp you'd start your car at? [Re: aarcuda] #189811
01/10/09 08:20 PM
01/10/09 08:20 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
I've run 20-50 below zero in years past. Even in a beater chevy or two.
Re: whats the coldest temp you'd start your car at? [Re: aarcuda] #189812
01/10/09 08:46 PM
01/10/09 08:46 PM
S.E.Ohio
Magnumguy Offline
Magnumguy  Offline
S.E.Ohio
Back in the mid 90's we had near 40 below. My 79 300 started, when much newer cars wouldn't. Is that what you were wondering?
"Multiple Magnum owner since 1978!!"
https://www.facebook.com/groups/146952895354657/
Re: whats the coldest temp you'd start your car at? [Re: buildanother] #189813
01/10/09 08:47 PM
01/10/09 08:47 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
20* below 0. Any colder than that and I would be out.
Re: whats the coldest temp you'd start your car at? [Re: stumpy] #189814
01/10/09 08:56 PM
01/10/09 08:56 PM
the boonies
aarcuda Offline OP
aarcuda  Offline OP
the boonies
well, i admit, any ol transortation car and i'll try and start it anywhere.
but im talking about my brand new 416 stroker thats sits for week at a time. filled with thick 20w50 oil.
surely you wouldnt start a car with 20w50 in it at cold temp as youd have glue for oil...
Re: whats the coldest temp you'd start your car at? [Re: aarcuda] #189815
01/10/09 08:59 PM
01/10/09 08:59 PM
Renton, Wa.
Classof70Chally Offline
super gas
super gas
Renton, Wa.
You used to be able to get an electric 'dipstick' heater that would go down the dipstick tube and preheat the oil. Don't know if you can still get them but maybe do a search?
Re: whats the coldest temp you'd start your car at? [Re: Classof70Chally] #189816
01/10/09 09:05 PM
01/10/09 09:05 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
When I lived here 13 years ago it got down to -40 f and I just wanted to see if my 68 dart would start and it fired right up after I brought the battery in to warm up for an hour. Yes it always had 20-50 in it. My 68 cuda started up the other day at -20 f but I run 10-30 in it and my 00 durango, my 91 dak started and it has 20-50 because it burns so much.
Re: whats the coldest temp you'd start your car at? [Re: aarcuda] #189817
01/10/09 09:05 PM
01/10/09 09:05 PM
I have a dipstick heater for the oil a block heater for the coolant & a trickle charger for the battery all wired to a plug in. With a timer its ready to go when I jump in it. it doesn't get that cold here but I like to pamper the baby(me not the car).
Re: whats the coldest temp you'd start your car at? [Re: RapidRobert] #189818
01/10/09 09:27 PM
01/10/09 09:27 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I'll run it at any temp but always have in the correct grade of oil for the temp.
Re: whats the coldest temp you'd start your car at? [Re: aarcuda] #189819
01/10/09 09:43 PM
01/10/09 09:43 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
I usually run straight SAE30 in the GTX, but I got distracted last time I changed the oil, grabbed the wrong bottles and currently it has 4 quarts of of 15w40 Castrol, and three quarts of 20w50 Valvoline.
I guess that gives me something like 17 and 1/2 W 45??
Oops
Oh well it'll get changed in the spring anyway.
If the multigrade oil is working properly, then it should act the same as straight SAE 20 at cold temps. To me that doesn't sound too bad.
What did people do before multigrade oil was popularized? They ran straight weight and started them up when needed, right?
But if this is going to be an ongoing thing, you'd probably be better served by a 10W multigrade, I would think?
Rich H.
Esse Quam Videri
Re: whats the coldest temp you'd start your car at? [Re: ZIPPY] #189820
01/10/09 09:45 PM
01/10/09 09:45 PM
Renton Washington
Triple Threat Offline
Renton Washington
My car has 20w50 in it, started it in freezing temps a couple weeks ago to move it. Crank the key til you get oil pressure then fire it up
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: whats the coldest temp you'd start your car at? [Re: stumpy] #189821
01/10/09 10:01 PM
01/10/09 10:01 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
I drove 60 miles to a neigboring city last week at 5:30AM and it was 35 below zero. The Dakota wouldn't shift into OD at that temperature. Usually have the block heater plugged in at anything much below 0. It has been well below 0 most of the last 3 weeks and the vehicles go every day. The wife's van doesn't have a block heater and it starts and she goes to work every day.
don't even think about starting one with 20/50 oil in it, I don't even like to think of that at 35 degrees. That stuff gets real thick in hurry. 10-30 is bad enough.
Re: whats the coldest temp you'd start your car at? [Re: MoparforLife] #189822
01/10/09 10:17 PM
01/10/09 10:17 PM
Ontario, Canada
78D150CLUB Offline
My avatar is a self portrait!!
78D150CLUB  Offline
Ontario, Canada
I run 15-40 year round and have a habit of driving away with only a very short warmup.
One day was so cold the wind chill thru the rad actually turned 50/50 antifreze to slush and I had to stop and wait for it to melt out to keep the engine from overheating. That's cold!
I want to die like my Grampa, peacefully, in his sleep. Not screaming in terror like his passengers.
Re: whats the coldest temp you'd start your car at? [Re: RapidRobert] #189823
01/10/09 10:35 PM
01/10/09 10:35 PM
the boonies
aarcuda Offline OP
aarcuda  Offline OP
the boonies
well you know, just because you can start it up and drive it, doesnt mean that its a good thing. I think youd get a lot more wear and tear on a motor started at really cold temps.
Re: whats the coldest temp you'd start your car at? [Re: aarcuda] #189824
01/10/09 10:45 PM
01/10/09 10:45 PM
Ontario, Canada
78D150CLUB Offline
78D150CLUB  Offline
Ontario, Canada
4-5 minutes while I clear ice and snow off the windshield and then city speeds for another 5-10.
I know that most wear occurs on cold start, but I was more pointing to that being the coldest I've seen when the moving air actually drops the temp below a tested -35 antifreeze.
I think the brass monkeys were all staying inside that morning.
Re: whats the coldest temp you'd start your car at? [Re: 78D150CLUB] #189825
01/10/09 11:12 PM
01/10/09 11:12 PM
wind chill only affects warm blooded people/animals. It can drop the temp of an object faster than it would drop if there was no wind but it doesn't drop it below the ambient temp.
Re: whats the coldest temp you'd start your car at? [Re: aarcuda] #189826
01/11/09 12:29 AM
01/11/09 12:29 AM
Wilmington,NC
I
I go fast Offline
I go fast  Offline
I
Wilmington,NC
You'd rather walk?
Re: whats the coldest temp you'd start your car at? [Re: aarcuda] #189827
01/11/09 02:57 AM
01/11/09 02:57 AM
DuPont, Washington
DZJim Offline
DZJim  Offline
DuPont, Washington
I lived in Anchorage for several years. It doesn't really get very cold there very often. I used 5-20 in the winter and started without preheat at -10F and din;t worry about it. If it is an expensive engine I'd be running 5-30 synthetic. Why 20-50 anyway? If you worry about it, get a block heater or tank heater.
Re: whats the coldest temp you'd start your car at? [Re: DZJim] #189828
01/11/09 03:27 AM
01/11/09 03:27 AM
You say it doesn't get cold in Alaska?
Re: whats the coldest temp you'd start your car at? [Re: aarcuda] #189829
01/11/09 09:52 AM
01/11/09 09:52 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Back in the 80s the day the Bengals played in the "freezer bowl" I think it was 20 below or something like that.I had a rusty 73 challenger with a hot 340 that I built. It was the only car that would start in my nieghborhood. It even sat outside all nite. I ran errands for all my neighbors that day because there cars woundn't start. After that day they never complained about the car being loud again.
Page 1 of 4 1 2 3 4
